Question about Pioneer AVIC-F900BT Car GPS Receiver
Setting coordinates while driving . . .
Is there any way you can override the system to allow setting new coordinates while driving? Its a pain in the **** if you change plans (as I do often) while driving and have to get off the highway, park, and then enter the new location I need to get to. Can anyone help?
  • Anonymous Mar 18, 2009
    sURELY THERE IS AN UNLOCK DEVICE WHERE YOU DO NOT HAVE TO APPLY THE EMERGENCY BRAKE TO ENTER AN ADDRESS!
I just fixed mine so it will work while driving ask me and ill let u know. you dont need to buy anything.
Posted on Mar 25, 2009
  • 4 Answers
I'll tell how to do it. You need to be somewhat technically inclined to pull it off. If you want to try it let me know.
Posted on Feb 03, 2009
  • 3 Answers
You can buy a kit to override the "parking brake required to be on" problem. I think I saw one on Ebay. Pioneer creates this situation so you can't "play" with the unit while you should be paying attention to driving - commercial installers won't install the kit for the same liability reasons.
Posted on Feb 02, 2009
Shifter interlock
what car, you never said? NOR YEAR?
park lock out feature;. its broken , they do that. (BTSI system)
got A/T? or M/T both auto and stick shift have lockout.
no car/year, you get the generic answer.
there is a park lockout DEFEATER on most cars, (never on new cars,due to federal bs)
on the shift console, see the defeat device.
the operators guide covers this. its for EMERGENCIES.
pick one.
http://justgivemethedamnmanual.com/jeep/
the A/T box,
Brakes + handle button press, unlocks BTSI
on 2005 and up , no bypass
if the key gets locked too, that tells you what is bad , on newer jeeps
on newer jeeps read this
http://www.lostjeeps.com/forum/phpBB3/viewtopic.php?p=366251
this feature (pain) has many failure points.
any cable that jams, there are 2 , one to tranny or ignition
switch. and the brake solenoid unlocker in shift handle.
and the button, to unluck shifter, brake switch (no brake lights/)
to diagnosis it is easy , dismantle the console at shifter
then disconnect cables to find if one is stuck, (easy huh?)
and defeat the solenoid, by hand or 12v applied. and check the button
that it does in fact release.
NOT PARK LOCKOUT: (for if not on flat ground?)
reason 2 , driver, parked on a hill with tire to curb and did so
not setting brakes first (or bad ebrake ) and now the tranny parking
pawl is jammed , opps. so wiggle the steering and wiggle shifter,
or have some one push car forward (parked up hill on right) to release
parking pawl. (or gorilla it, ask bubba to muscle it out of park.)
if down hill , well, you get the idea..... pain.. gotta love A/Ts not.
Folks in Sanfranciso, just roll eyes at you, new in town>?
now the grand cherroke,, why not post car model, and year, dang.
quote 2010 oper guide, get one.
Brake/Transmission Interlock Manual Override Your vehicle may be equipped with a shift lock manual override. The manual override may be used in the event that the shift lever should fail to move from PARK with the ignition switch in the ON position and the brake pedal pressed. To operate the shift lock manual override, perform the following steps: 1. Turn the ignition switch to the ON position without starting the engine. 2. Firmly set the parking brake. 3. Using a flat-bladed screwdriver, carefully remove the shift lock manual override cover, which is located on the PRNDL bezel. 4. Press and maintain firm pressure on the brake pedal. 5. Using the screwdriver, reach into the manual override opening. Press and hold the shift lock lever down. Interlock Manual Override end quote.
no all jeeps have this,
Feb 06, 2014 | Jeep Cars & Trucks
Override Password
You probably have set the settings that requires a password immediately after the screen goes to sleep or when screen saver kicks in.
Goto: System Preferences > Security & Privacy > General... and untick the setting "Require password....." or change the setting to allow for some more time.
hope this solves 5085e8ad-f87b-45c6-9851-a53f99c18be5.pngyour issue
May 15, 2013 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
How remove child lock?
Hello
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
Mar 17, 2011 | Apex Digital PF3220 32" TV
I'm unable to get a picture or sound due to a "key" lock appears in the lower left hand corner of the screen. It will not allow me to unlock it.
Hello
Your TV is locked. Do the following to unlock it.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desiredOK.
Jan 29, 2011 | Apex Digital AT1314DV 13 in. TV/DVD Combo
How do you unlock an apex 27 inch tv
Hello
OK
Happy New Year
Dec 31, 2010 | Apex Digital AT2708 27" TV
Hi when i start up my system, (Insp 1520, Winodws Vista) consistantly (loops over and over each time it reboots) requires "repairing files, this may take a few minutes to over 1 hour" . I dont...
hello
it sounds like you need to order the CD recovery set from Dell (cost about $50). Once you receive the recovery Cds, start up system, insert the CD and press F2 to override the start up to repair files. Once you get to the screen (F2), select "boot from CD", press ENTER, and the system should get you into restore to factory default (FORMAT DRIVE) . From here on , you can format the drive and reisntall the OS . It will prompt you to insert the MULTIMEDIA CD . This will allow you to restore to original factory setting.
please issue 4 thumbs up so i can remain available to you.
Dec 08, 2010 | Dell Inspiron 1520 Motherboard
How do i reset an apex tv set with model number gt2715?
Hello
You are locked out I thinks. Try the following to override the locking.
OK.
Dec 02, 2010 | Apex Digital GT2715 27" TV
I havnt used my dv8000 in over a year because i purchased another laptop, however im trying to sell it but i cannot remember the power on password, is there anyway to override or bypass it?
Start the laptop holding down the f11 key till you hear a beep.
Then the system restore dialogue box comes up which allows you reset the system to the factory setting as if it was brand new.
Good luck.
Remember to rate this.
Dec 08, 2009 | HP Pavilion dv8000t Notebook
Entering new location while driving.
You can find kits to bypass the "needs the parking brake on" issue - seems to me I saw one on EBAY - my installer told me about them but they can't legally put them in when they install the unit.
Jan 21, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
Pioneer AVIC-F900BT Car GPS Receiver Logo
160 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
