Question about Dimplex EPX1000 Heater
How do i unlock the contols on a dimplex epx1500 panel heater
How can I obtain operating instruction for Plx 7.5 kwn
Try
Download From This Blogdownloadfromthisblog.net/47023-dimplex...heater-manual.html
Hope this helps
Feb 13, 2015 | Dimplex Compact Electric Flame Stove...
Need replacement grille for Dimplex floor drop-in heater FFIH15A31
Get the dimensions of grille and contact dimplex, or plumbing & heating supply store for new grille.
Apr 15, 2014 | Dimplex FFIH15A31 Electric Heater
Dimplex PW4 timer not working with heaters
In UK, you can call 0845 600 5111
The manual is very unclear about:
1) Wiring.
2) Resetting the timer when encountering a problem due to surge, power outage, or malfunction.
3) Troubleshoot section is missing.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/RXPW4_Instructions_Issue_4.pdf
Jul 25, 2012 | Dimplex Epx1250 Panel Heater
Can i use a normal 13amp plug on a dimplex plx1500 panel heater
Probably not the best idea. It may overheat when the heater is running at the high setting. Best to use a 15A rated cord and plug.
Nov 01, 2011 | Dimplex Compact Electric Flame Stove...
How do I change the bulb in my dimplex wynford inset fire?
On the back of the cabinet, about 3" to 4" up from the bottom, you should see a removable rectangular panel. Removing it, will give you access to the bulbs. Which are 60 watt, small base chandelier bulbs.
Turn the unit OFF & Unplug it, before removing the rear access panel.
Hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Dimplex DS5603 Heater
I am looking for an instruction manual for the Dimplex OFC2411TIF Oil Heater
Carly, the owners manual for the model number you listed is not available online. However, if you call Dimplex USA, Technical Service 888-346-7539, they can help you.
Apr 06, 2011 | Dimplex EF12 Electric Wall Mounted Panel...
The setting on the dimplex wall mounted heater is locked on 'auto on'. Please tell me how to unlock it. I have tried, but...
Tereca, the quickest way to answer your question is for you to Call Dimplex USA, Technical Service at 888-346-7539. And if you have misplaced your Owners Manual, ask them to please send you one. Have the Model Number of your heater handy, when you call.
Mar 20, 2011 | Heating & Cooling
Can't unlock the control panel
Usually in sequence... Program-Mode-Temp Down... Or temp Up to lock
May 24, 2009 | Coleman (5040B750) Patio Heater
No Heat or fan on model DS4411 Or 6901050100
I had the same problem. One or more of the switches for the stove have melted and broken. You need to call Dimplex and request new switches. They should ship you out a 3 pack for free, and the pack will come with easy instructions for removing the bottom panel and replacing the switches.
Dec 22, 2008 | Dimplex DS5598 Mid-Size Heater
Dimplex EPX1000 Heater Logo
77 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
