Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Loud ticking noise coming from motor and motor runs rough.
Just started ny harley after it has been sitting in my garage for about three weeks. the tempertures here have been in the single digits. The bike did not start as easily as usual and refused to idle. I noticed a ticking sound coming from one of the cylinders. When I checked the oil it was much thicker than usual. I let the bike run for a few minutes hoping that it would thaw out, but it just missed and then quit. I wa thinking that I should put a heater on the engine and then replace the oil with new oil that is room temperatuer or even warmer to see if that works. What do you think and do you think that I could have damaged anything by letting it run for those couple of minutes?
  • Mel Jacobson
    Mel Jacobson May 11, 2010
    Are u using a multigrade oil ?
    Problem Solver:
  • 8 Answers
U didnt hurt anything,make sure u're using  multigrade motorcycle oil
Posted on Jan 26, 2009
What year model . older bikes first check screen in oil pump. check oil lines . depends on carb you may have to make some adjustments . i live in south were we have humidity no matter what the temp is . and some times have to make adjustments to prvent fouling . check bowl on carb for any trash . once you get it started if you still hear ticking you may need to check push rod adjustment .
Posted on Jan 31, 2009
2006 cts 2.8 making loud ticking noise ,running rough and has misfire codes po300,301,303,305
codes p 300 is a random/ multiple misfire===causes spark plugs---HT leads ---injectors/s--ignition coil/s--low compression---wiring
codes p 301,303,305 are misfires detected for no 1,3 5 cylinders === causes listed are engine mechanical fault---wiring---ignition/fuel systems ---injectors---ECT/MAF sensors---ECM
You do not mention if this is a v6 engine in which case no 1,3 5 will be all in the one bank head
With the loud ticking noise that amounts to a mechanical fault associated with that bank
could be loose valve seat inserts , cam lobes failure or cam follower failure or hydraulic lifters problem even loose cam shaft bearings / caps
I would be inclined to remove the rocker cover and check for metal , loose bolts , excessive valve clearance before I went plugs etc
the main indicator for the answer is the loud ticking noise which indicates a valve train problem which will cause the rough running
Jan 15, 2016 | Cars & Trucks
Had ticking sound started up this am loud pop then rough running like there was no muffler
Ford Windstar Starting/Stalling Problems - Car Forums at Edmunds.com
forums.edmunds.com > Ford > Ford Windstar
Oct 16, 2007 - 31 posts - ‎26 authors
Learn more about Ford Windstar at the Edmunds.com Car Forums! ... I tried to startmy van on a 15 degree morning - heard a loud bang and now it won't start. Battery ....The engine will crank, start run about 5 seconds then stop. ... I have a 2003 Ford Windstar, same problem,Ford is covering up the problem.
Why My Car Won't Start? - Reasons and Solutions
www.myautorepairadvice.com/car-wont-start.html
As a rough guideline, problems with the battery, alternator and starter are the most ...Before I even put the key into the ignition I hear a clicking noise on the right side ...started it and then it started making a loud clicking noise while I was driving it ..... i have a 2003 windstar ford it was clicking and wouldn't start had to get a ...
Rough Idle Engine Dies Loud Ticking!?! Please Help! - Ford Focus ...
www.focusfanatics.com/.../103146-rough-idle-engine-dies-loud-ticking-...
Nov 6, 2006 - Rough Idle Engine Dies Loud Ticking! ... down then dies and then i restart and it has no problems but the ticking continues PLEASE HELP ME ... Level Up0% Completed ... 2. my injectors are bad and the ticking sound is one of the injectors.... Another method is to turn the AM radio on to a place where there ...Missing: windstar
Jan 08, 2016 | 2003 Ford Windstar
I have a 2008 Dodge Durango, 94k miles. Every time I start the truck after it sitting for a while (in the mornings or when I am leaving from work), it has a loud ticking noise and the engine sounds really...
Sounds like the valve lifters are taking longer than normal to pump up with pressure. Getting the motor cleaned out and de-sludged would help. also use good quality oil after the cleaning.
Nov 01, 2013 | Dodge Durango Cars & Trucks
1990 honda accord ticking and knocking, motor running rough
Hi, You need to get the engine mounts especially in this case the front one replaced, the quicker the better as you only end up with more problems if left to long. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 03, 2017 | 1990 Honda Accord
I notice my oil was low, cause it was running a little rough. So I put a quart in. Then it was running better. Then I drove it the next day and it started making a ticking noise and now it is getting...
the ticking , if you hear it on the top of the motor, will be a rocker arm,, it could be plugged and not getting oil, if its coming from lower down in the motor, it is possibly a stuck valve,, or a rod bearing , if its a ticking noise its more than likely the rocker assembly,, if its more of a knocking noise its lower in the motor
Sep 12, 2011 | 2005 Chevrolet Cavalier
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
My 97 excel has a rather loud ticking noise coming from the engine does anyone know what it is and how to fix it?
Check the oil! A ticking noise is most commonly a sign that there's a lack of oil running through the motor. Start the car and listen for general vicinity of the ticking noise. If the oil is fine and the noise is coming from the engine, there are oil additives that will quiet the noise. Ticking is also a sign of an old motor (guessing you have about 150K on this car) I hope this helps clarify your problem and wish you well with your car. All the best!
Greg
p.s. Please don't hesitate to post back regarding this issue or any other questions!
May 12, 2009 | 1992 Hyundai Excel
The engine won't stay running
Pull the large hose off of the throttle body that come from the air filter and clean all the carbon out of there if is real bad pull the throttle body so you can get to both sides and clean use carb cleaner
Mar 25, 2009 | 1995 Chevrolet Lumina
LOUD TICKING NOISE IN ENGINE AFTER INTAKE REPAIR
How long have you ran the engine ? I know that they will run rough and sometimes make strange noises for a few secounds or a little bit untill everything get oiled up again. I would make sure all the push rods are back in the right place and that all the lifters are tight.
Jan 18, 2009 | 1998 Pontiac Bonneville
Lands Phones Logo
298 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
