Question about RCA F36650 36" TV
I have sound but no opicture
I found a solution to my first problem of 3 clicks when the set is turned on but never actually comes on. I replaced the flyback, also the resistor, and cap that came with new flyback. Now I get sound but no picture. I can feel the static on the front of the screen and the picture tube is coming on. Is there a setting I am missing or did something else get fried. Originally the set got real bright, then shut off. I could see an arc at the back of the flyback when you turn the set on, corresponding to the three clicks.
  • 8 more comments
  • Ray Pete Jul 03, 2007
    I went through the channels and managed to get one that came up but very dark. Adjusting the screen control had no effect. The screen is too dark to see the OSD for adjusting brightness.
    I have one concern, relating to the disk capacitor I replaced. I know that electrolytic caps have a pos and neg, do disc caps as well. This cap wasn't marked and the pcb wasn't as well.
    Could there be another resistor gone bad. I have replaced one in a computer monitor before to take care of a too bright screen.
  • Ray Pete Jul 04, 2007
    I have been playing around and I seem to only be getting red, no blue or green. Also I have noticed when a very bright picture comes up on the screen, I don't have the osd for volume when I adjust the volume, and the menu doesn't show up either.
    Is it time to right off this TV??
    I got the original RCA flyback replacement (which set me back $75). The data sheet showed a picture of two different pcb types. The older one required the jumper, between pin 7 and 8, the new one did not. I double checked and had two other people look at the diagram and pcb to make sure I had the new one. I also gently tugged on the wires in the chimneys to make sure they were seated, but will check again. I will also check all my solder connections again.
    Thank you very much for taking the time to respond to my post.
    OK--upon flipping through more channels, I found that the blue and green guns are working, but I am not getting white. I need to realign the RGB and I can't see the on screen menu at all. Is there an adjustment somewhere inside. The focus control seems to add and subtract a little brightness but doesn't seem to affect the focus, the screen control still does nothing. Is there a possibility the flyback is bad.
  • Ray Pete Jul 05, 2007
    With both wires removed and as far away as possible, I get a maximum of 108 volts. I am adding an image of what I get for a picture, maybe that will help.
    By the way---the image is ShopNBC channel
  • Ray Pete Jul 06, 2007
    Thank you for all the help. I hope the place where I bought the flyback will go good for it. If not, is there a place you could recommend that I could get another one.
  • Ray Pete Jul 13, 2007
    OK---New flyback, all installed, same problem.
    Low voltage at screen wire, even with focus wire removed. I checked spark gap, just to be sure, and it's clean.
  • Ray Pete Jul 16, 2007
    Yes, I'm sure I'm turning the screen control.
    I'm checking voltage through screen control at cold ground. should I be checking it some other way?
    I have been researching and one cause of low voltage is a defective tripler. I can't seem to find anywhere that gives the output voltages of the tripler. I checked across snubber cap and I'm getting 157v dc with power off, manual says I need at least 140, so ok there.
    Pin 3 of the flyback goes to 330v from the 157 at power up. I can't measure pin 1 and 2 of the flyback, my meter only goes to 1000v. Should pin three be higher.
    P.S. I really appreciate all your help, once I get close like this, I have an obsession with finding a solution.
  • Ray Pete Aug 13, 2007
    Well I trashed the TV. Thanks for all the help, I learned a lot about TV's during the experience.
  • 398 Answers
When you replaced the flyback the new flyback is shipped with the screen and focus controls set at minimum. These are the 2 controls on the flyback itself. Turn the set on and let it warm up a minute, then slowly turn up the screen (bottom) control with a small flat-head screwdriver. When the picture is around normal brightness, adjust the focus (top) control until the picture is nice and sharp. Then, turn the brightness and contrast all the way down and set the screen control until you can just see the picture, just above the point where the picture vanishes. Reset the brightness and contrast settings and your picture will be back to perfect.
Posted on Jul 03, 2007
  • 3 more comments
  • Mike Longo
    Mike Longo Jul 04, 2007
    The small disc capacitor you replaced has no polarity, so it does not matter which way you put it in. I have never seen any other resistors in that chassis that would cause low brightness when bad. On the early version of those sets there was a small surface-mount jumper between 2 of the flyback pins (2 of the pins on the tuner side of the flyback) and it was very easy to accidently unsolder that small jumper while unsoldering the flyback. Double check the board to see if there is a space between 2 of the pins for a surface mount jumper and if it is still there. A surface mount jumper looks exactly like a surface mount resistor but it is labeled "000". When you installed the new flyback, did you make sure that the screen (yellow), focus (thinner red) and high voltage (thicker red) wires were properly inserted into the correct flyback chimneys, or did you install a cheap generic replacement?
  • Mike Longo
    Mike Longo Jul 05, 2007
    If you turn the screen control and the brightness does not change, and if you turn the focus control and the brightness changes a little then there is definately something still wrong with that circuit. Since the flyback is brand new I do not suspect it to be bad. Do not try realigning the RGB bias/drives until the flyback is working properly. Measure the screen voltage on the CRT socket using a voltmeter set to 1000 volts. It should vary from about 200 to 600 volts as you turn the screen control on the flyback. If that voltage is way too low then remove the screen wire from the CRT board and measure the voltage in the wire itself (unloaded). If the voltage in the screen wire is still low then remove the focus wire from the CRT socket and move it away from everything else, and then measure the screen wire. If you have good screen voltage when the wires are disconnected then you probably have a shorted spark gap in the CRT socket itself. I saw this symptom once when a flyback went bad and sent too much voltage through the screen and focus wires, causing arcing and burning in the CRT socket spark gaps. If this is the case then you will have to disassemble and clean the spark gaps inside the CRT socket or replace the socket.
  • Mike Longo
    Mike Longo Jul 06, 2007
    If you disconnected the focus and screen wires, turned the screen control all the way up and you have 108 volts on the screen wire, then the flyback is defective and you should exchange it for another one. You should have around 600 volts.
  • Mike Longo
    Mike Longo Jul 07, 2007
    I get original RCA flybacks from Union Elecronics in Beecher, IL (800-648-6657), Herman Electronics, AKA Panson (800-938-4376) or Fox International (800-321-6993), in that order.
  • Mike Longo
    Mike Longo Jul 16, 2007
    Are you SURE you are turning the screen control up? Are you using a small flat-head screwdriver and are you sure the screwdriver is actually turning the control? I cannot think of any other reason that the screen voltage would be low. Your high voltage and your heater voltages must be right, or you wouldnt see anything on the screen, so the flyback must be working and therefore the screen voltage must be ok too.
SOURCE:
I've tried everything, can't get sounds for in coming texts
go to your settings. click on sound. here you should find a notification option and set which ringtone you would like. make sure that you go back to your sound settings or caller settings to make sure the volume is actually turned on for incoming text messages. the reason you might not be getting them is because you have it default in your phone to keep them silent. just browse your setting options for sound or calls where you will find a "volume" option. select that and slide your notification sound over to whatever level you like! hope you found this helpful!
Dec 29, 2012 | ZTE Warp
No audio output device found on windows vista, hp
OPEN YOUR "CONTROL PANEL"...THEN OPEN "HARDWARE AND SOUND"
2. LOOK FOR AND CLICK OPEN "DEVICE MANAGER"
3. SCROLL DOWN TO '' SOUND,VIDEO AND GAME CONTROLLER''
4. RIGHT CLICK "SOUND VIDEO AND GAME OPTION"...THEN AN OPTION WILL COME UP SAYING..."SCAN FOR HARDWARE CHANGES"...CLICK IT OPEN YOUR "CONTROL PANEL"...THEN OPEN "HARDWARE AND SOUND"
May 15, 2010 | HP Pavilion dv8000 Notebook
RCA light comes on and then goes off. Tv doesn't turn on
replace CP150 and CP114 you can get them at the following link they also have the ITC222 service manual which is listed under Thomson as Thomson makes your TV for RCA. The Capacitors are listed under the RCA parts and they do send instructions with pictures of where the capacitors are located as well as how to remove the board.
http://servicemanuals.vstore.ca/
May 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Takes awhile for tv to come on!
Hello Ruben,
This type of failure is common on these TVs. The power supply might need to be replaced due to bulging capacitors. If you are able to replaced the capacitors, it is a cheaper alternative.
Check the link below to find service parts.
Jun 12, 2017 | Televison & Video
Directional signals make vitually no audible when clicking
There is a turn signal switch device found under the dash that can sometimes be placed in an area that impedes the sound from reaching the driver. Turn the signal on while parked and in a safe area and listen for the source of the turn signal sound under the dash. Many times they are found along the steering column. Use a long screwdriver touched on the actual assembly and place the handle to your ear to verify that this is the correct assembly. If it is and it's not blocked somehow, check with a parts store for a replacement and tell the you would like one that has a substantially louder indicating sound. They should be able to accommodate and once replaced should resolve this safety issue.
Feb 11, 2009 | 2004 Toyota Highlander
Kenwood BB5
replace capacitor 110 (47uf 25v), it fixed the exact same problem for me, it should cost about 25 cents and take about 1 hour of your time :-)
Jun 11, 2008 | Audio Players & Recorders
Blinks twice pause blinks 4 times
SYMPTOMS
Dead or Shutdown symptoms.
RESOLUTION
Dead symptom reported to be caused by the following:
1. Dead.
Found Q601 & Q602 shorted, R615 open, and IC600 on the A Board were the cause of the symptom.
2. Dead.
Found D614, Zener diode, on B+ line was shorted.
3. Set shutdown and the standby LED blinks 3 then 5 times.
Found 200v line was low. Disconnected CN706 on the C Board and found 200v now
present on CN706/pin 7.
Found: IC702 (C board) shorted the 200 volt line.
HQ Comments: C541 on the A Board could become defective if the 200v line is shorted since
the polarity on the capacitor will become reversed. R553 fuse resistor could also be opened
on the A Board.
4. Error code of 4 blinks .
Dead set press power button you hear the relay and you see red led flash 3 times and stops? Has no HV or other action. Tech removed the back as no 200 volt supply, did unplug CN706 and now has 200volts. Tech did remove the IC702 and same it comes up so needs this IC.
5. Dead. 5 blinks then 3 blinks. Found shorted Damper diode D504. Q502 has a built in damper, as well.
6. The TV does not turn On and the LED flashers 9 times.
Found one side of R610 open on the Base of Q690 on the A board.
7. Dead, 9 flashes, Q606
Would not start when cold, has stand by 5 but relay never energize.
No response from front panel or remote controls.
9 blinks is not in service manual.
Found Q606 (Zero Det.), on the A Board, had no soldered on the collector
of the transistor causing an intermittent connection.
Soldered the collector of Q606 and set returned to operation.
HQ Comments: Also refer to E30968554.
8. Dead. 5 blinks or 3 blinks
Found on the A Board D611 in the Power Supply open, and Hor. Output Q502 shorted.
9. Found Power Supply components D611 shorted causing Q600, Q601, and R615
to fail on the A Board.
10. No picture or sound. Standby flashes.
Found Q512 (Pin Out) shorted. on the A Board.
11. Dead. No sound or picture.
Found the FBT and Q502 were shorted, and R615 open on the A Board.
12. Dead
No power, Stand by light flashes 4 times.
Found T604 and IC601, replaced.
Found D611 on the A Board was the cause of the symptom.
13. Dead.
Found D534 shorted on the A Board.
14. Shutdown 4 Blinks.
Replacing R595, OCP Latch Q532 on the A Board, fixed the set.
PN 1-247-891-00, 330K 1/4 watt.
15. Unit shuts down after 15 mins.
Immediate shutdown - sometimes it give a 3 blink, sometimes nothing.
Found R595 (330K) was open located in the Q532 OCP Latch circuit.
R595 P/N 124789100 330k 1/4w
16. Won't power up. LED Blinks 4 times, B+ is very low
B+ is at 49V, +15/-15 only coming up to about 1 volt.
Wth Hor Out disconnected B+ only comes up to 50v.
17. Intermittently does not turn on
Found a intermittent C633 on pin # 3 of IC600.
C663 P/N 113647911 Film cap .001uf 100v
Billy
If you need the service manual contact me at:[email protected]
Jan 27, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Is this your set?http://tv.rca.com/NR/rdonlyres/A2ED8EB5-A0AF-401F-A380-3CB61D5EBEB1/0/D52W20_222Chassis.pdf If it is, there could be a bad solder connection in the start up power supply or there is a resistor that will get loose or change value. It gives the power supply the start up pulse from the flyback transformer. there are no user replaceable parts inside this set, and the longer you wait to get it serviced, the more its going to cost. Unless you have a service manual and understand how the SMPS works, please play it safe and call in a pro to assist you in this repair. Good Luck Please do not forget to rate this thread.
Dec 09, 2006 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture
If you know how to service TV sets then you have to first determine if the problems in the HI voltage sweep circuit or the video. Try first to turn up the screeb control. If you get a white opicture then you have HI voltage so you have a video or video drive circuit problem. your going to need a service manual as well as an ocilliscope. to trouble shoot this set. if you dont understand what Im saying PLEASE call an experienced tech to assist you in this repair. good Luck
Aug 09, 2006 | Zenith IQB36B86R 36" TV
RCA F36650 36" TV Logo
139 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
