Question about Audio Technica Audio-Technica 200 Series Freeway ATW-252 Professional Microphone
Wireless noise I have an audio-techica ATW-R03 wireless transmitter which I use with my bass. Every now and again it makes loud static sounds and cuts out temporarily. I've tried changing the setting from low to high on the unit that plugs into my bass. On the receiver is a pot that says 'squelch'. What does this do? and will this help my problem? thanx, Caleb.
This is a very cheap unit but yes squelch is a factor.keep, fiddling with it.Very seldom do bass/guitar players like wireless.
Posted on Mar 21, 2010
The unit I'm using is old and is on a 200mhz frequency and it uses Vhf, so I have to buy a new unit.....nothing can be done to fix the problem....
Posted on Jan 22, 2009
Change battery on ATW-T210a
Here's the owner's manual for that series. You'll find the battery replacement instructions on page 6: http://eu.audio-technica.com/en/resources/2000a%20Series%20Owners%20Manual.pdf
Nov 12, 2013 | Audio Technica Audio-Technica ATW-T210...
Intermittent LOUD shorting sound
I would prefer to hear it to be sure which one it is, but the four biggest causes of noise in a wireless system are: 1) Something hitting the mic (check to make sure the mic is free of clothing, other people, faces, etc.) 2) If the mic is a lavalier or in some way has a cable that plugs into the transmitter, something pulling on it could create a loud noise. Check to make sure it's in snug. 3) RF Interference with another mic or some other interference source. Try changing the frequency. 4) Something blocking the signal between the transmitter antenna and the receiver antenna. This is most likely to happen with a lavalier in someone's pocket or under clothing, and/or if the transmitter is far away from the receiver. The SLX series is okay for what it is, but part of why it's on the cheaper side is because of its limited distance. Unfortunately the only ways to alleviate this are to a) Reduce the distance, b) get a stronger wireless system, c) move the transmitter somewhere that the antenna is free, and d) invest in True Diversity antennae for the receiver.
Sep 23, 2013 | Shure SLX4 Wireless Receiver with Antennas...
I have 2 velodyne fsr 12 subs. both were taken out by PG&E power surges. One make a white noise that cuts in and out, but will still play bass when fed a signal, the other makes a loud static sound...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Velodyne-FSR-12-Subwoofers-manual/id/866ag600/t/2/
Not that it would help.
Is the white noise present in the absence of an input connection, free-floating?
The amps in both of them sound like they
Mar 24, 2011 | Velodyne FSR-12 Speaker
Mic receives a lot of static and then cuts out. After a few seconds it seems to repeat.
This could be due to interference from other devices.
You could try changing to a different frequency (there are 20 to choose from).
Also move the receiver away from any strong electro magnetic fields (hearing loop amplifiers, CD/DVD players, TVs) or large pieces of metal and in clear line of sight of the transmitter pack.
Set up the aerials so that they are at a similar angle as the aerial on the transmitter.
Only use xlr balanced cables with good quality screening to connect the receiver to the mixer / amplifier. Keep signal cables well away form mains electricity cables as far as possible.
Wherever possible use balanced xlr cables on all other equipment.
Feb 13, 2011 | Audio Technica ATW-R11 Microphone
Turns itself off every 5 min to extremely loud static
If you're using a mac, I've made an instructable on how to make this a little more bearable..
http://www.instructables.com/id/Wireless-Headphones-3-minute-transmitter-cut-off-f/
Hope it helps..
Rob.
Jan 16, 2011 | Sennheiser RS 110 Consumer Headphones
I have a atw-t52 audio techina wireless mic. And when i turn it on thr crackling begins to come through the speakers and i have to play with the input and output cable and move the base unit around and...
I have the same problem in my ATW T52, in st by its ok (the rf leds show perfect signal) but when i set in on the af level start punch and i hear in the monitor a noise like a heartbeat (pum-pum-pum....) Please any answer for this problem
German
Radio del Sol 96.3 Mhz
Villa de Merlo - San Luis
Argentina
May 20, 2010 | Audio Technica ATW-T52 Professional...
Replacement lavalier transmitters
The ATW-R12 is not made any more. We here at Pro Line Music are Audiotechnica Dealers. I would need to know what frequences the transmitters are to see if there is another unit that can match thoes frequences. call 215-736-8055
Jan 02, 2010 | Audio Technica ATW-R12 DIVERSITY RECEIVER...
We have a Sennheiserew100 G2 mic kit with a wireless lav mic and transmitter we use for a canon xh-a1. The shotgun mic has been prefect but the lav mic is creating a static/noise in the background but then...
This is probably interference in the wireless connection for the lavalier mic.
Try switching channels to find a clear one!
Or switch to a wired lav mic if that's practical.
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Apr 13, 2009 | Sennheiser 100/500 G2 Series Wireless...
Vocals disappear in parts using this mic
It is very common to have the squelch on the receiver set at full or much too high. With the audio output unplugged or at least turned all the way down, and with the transmitter turned off, locate the squelch control - you may need a screwdriver depending on which model of receiver you have. Turn the squelch control counter-clockwise until the TX light turns on, then turn it back up just past the point where it turns back off.
If you turn it all the way down and the TX light doesn't come on, that's okay. If you get blasts of noise occasionally when the transmitter is turned off, then set the squelch a little (only a little) higher until it stops.
Joe
Jul 21, 2008 | Audio Technica ATW-T52 Professional...
Audio Technica Audio-Technica 200 Series Freeway ATW-252 Professional Microphone Logo
1,083 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
