Question about Zanussi Ovens
When turning on zanussi combi oven it shows error eo25
3 Suggested Answers
k14cks
  • 5 Answers
SOURCE: Hi I have a combi rational oven shows error 10 . What should I do? The oven didn't do cleaning and has error then service 10 appeared. Thanks
Service 10 is usually caused by a blocked or defective steam generator emptying pump.
Replace the pump or clear out any scale buildup.
Once the problem is corrected you must do an automatic drain to clear the error.
Posted on Feb 28, 2017
Why combi oven error code 32
If it is a Rational CM or CMP gas oven, then there is a problem with the ignition module.
Feb 03, 2017 | Combi Ovens
I have rational CM61 E ,display showing error E12, if know this anyone pl. share this
Hi, error 12 is displayed when the oven pcb is too hot, check that the air filter is clear and the cooling fan is running. Also it could just be the software, if it is an older oven and has the original software then it may just need upgrading by someone who knows what he/she is doing.
Jan 05, 2014 | Combi Ovens
STEAMER NOT WORKING SHOWING E8 FAULT
Hi, error 8 is showing you there is something wrong with temperature control pot. This is soldered to the pcb so you need to get someone to replace this or check the connections, otherwise the pcb needs replacing
Nov 28, 2011 | Combi Steamer electric built in steam...
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
ZANUSSI Oven E025
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
May 15, 2010 | Zanussi ZBF360 Electric Single Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Jan 06, 2009 | Zanussi Ovens
Ovens Logo
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
