Question about Sony VAIO GRV550 Notebook
I got white display on my LCD screen, VGA output still worked.
How to fix this problem ?
We need more details like: where are you connecting your laptop to,
is it to the tv.. ect.
Posted on Jan 21, 2009
How do i fix when i hook up hdmi cord and the screen wont display and when i hook up vga it does but i want hdmi for my ps3?
You must have to make setting in your ps3 and Display device. Set the display device at auto option for input source. It may be set at VGA. that why you get output of VGA but it does not display output from ps3
Mar 30, 2015 | Hannspree HF199H 19 Flat Screen LCD...
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
EasyNote LJ71 has a dead screen and won't output to VGA/HDMI
There will not be any display at all if the RAM is bad. Please try with a good working RAM.
Nov 20, 2013 | Packard Bell Lj71-sb-086ge 17.3" Laptop...
Dell 1545 laptop with white LED screen on start up. Works fine when connected to external screen via vga connector. Everything else works ok. Broken & remade connections between mobo & screen = no...
If the display works fine when connected to external screen via VGA connector then then the problem is either with the LCD display panel ( which consists of the display panel and inverter ) or the LCD cable that connects the LCD to the motherboard. You could try to re-seat the cable connection on the back of the LCD panel.
Aug 01, 2011 | Dell Inspiron 6000 Notebook
When I started using Netflix, I hooked the Samsung Flatscreen TV up to my Dell Inspiron laptop via a VGA cable and it worked beautifully. Suddenly, the TV indicated that there is no signal. I checked the...
Most laptops have 3 video-display options:
* output only to internal LCD screen
* output only to external VGA port
* output to both LCD and VGA
Hold down the blue 'FN' key on your keyboard, and look at the BLUE labels on/above the 12 'F' keys. One of those Function-keys can be used to "toggle" through the above 3 display modes.
Jun 04, 2011 | Samsung Computers & Internet
Dell M2300 issues: After several times of a freezed screen & rebooted the computer while either on the internet or working with "Autocad Inventor", it's finally gave up on me, on the last...
Isolate where the problem is: it could be the LCD display or the graphics circuit on the main board. Connect the VGA output of the laptop to an external monitor - one that you know is good. From the function keys, activate the VGA output of the laptop - it's suppose to switch between the LCD display or to the external monitor. Switch it to the external monitor. If the external monitor works, then you have a problem with the LCD display of the laptop.
Dec 22, 2010 | Dell Precision M2300 Computer Workstation ...
LCD VGA Display goes on and off.
Check refresh rate and setting for external display output. It won't work with unsuitable screen resolution, color depth or refresh rate. Check all three points and I believe you can troubleshoot the problem this way.
Jun 02, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Acer aspire 5102wlmi vga output
kindly u have to switch this vga output on there is toggle button
press Fn along with it press F5 button clearly marked with two monitors black and white this will enable the second output
and one more trick on the right side in the taskbar in the intel graphics accelerator icon right click and select dual display mode there as well if u have ati it is the same case see there in the task bar
pls rate me FIXYA if i fixed ur problem
Mar 03, 2009 | Acer Aspire 5102WLMi Notebook
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Computer monitor
I have never tried that but I would say it won't work that way. I have 2 display cards (3 outputs each, VGA, DVI, TVout) and 3 monitors. When I check the driver software and multiple screen function, it shows only 2 output (VGA and DVI) each. I cannot set TV output as a second screen. Even display properties on windows, it shows only available monitor output. I don't think you can do that.
Thank you,
Tan
Mar 05, 2008 | Dell E153FPc 15" TFT LCD Flat Panel...
Sony VAIO GRV550 Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
