Question about Celestron 44345 Microscope
LCD Monitor in 44345 not working - Celestron 44345 Microscope
Good afternoon. I bought a Deluxe Digital
Hello, Have you tried putting something under the microscope and then trying to focus on it?Maybe the lens is out of focus. See if there's nothing obstructing the lens. If problem persists after trying those two things you should probably send it to warranty as there most likely is a bad connection between the lcd and the camera.
Hope you can fix it easily.Best regards Vlad
Dec 01, 2011 | Celestron 44345 Microscope
I cannot adjust the brightness on my Acer 5420-5687 laptop. The laptop had frozen so I unplugged it and took out the battery which reset the brightness. I tried using Fn key and holding the either sun...
I'm sorry my friend but seems your LCD monitor having problem. There are three options with your LCD monitor. Option 1: repair your LCD monitor *commonly problems are the LCD inverter*. Option 2: Replace LCD monitor with a new LCD monitor. Option 3: Instead using your dim LCD monitor plug CRT or LCD monitor external serve as your monitor. Have a nice day.
Jan 26, 2011 | Acer Extensa 5420-5687 Notebook
Need new drivers for Hyundai Monitor Drivers IT
Try connecting the LCD monitor to a notebook computer.
Set the notebook's video to 800-by-600 and 60 Hz,
to see if the LCD monitor will accept these settings.
Set the notebook's video to 1024-by-768 and 60 Hz,
Set the notebook's video to 1280-by-1024 and 60 Hz,
Restart your desktop computer in "Safe Mode",
after reconnecting the LCD monitor, and use the settings that work
when the LCD was connected to the notebook.
Nov 09, 2009 | Hyundai Electronics ImageQuest N91S 19"...
Dell monitor black screen
If you have another monitor for desktop hook other monitor up then under hardware and software in control panel, add the dell monitor, then hook it up. Some operating systems need the driver to be added first. My brother almost threw away agood dell lcd monitor before I told him this, now he loves the lcd, works great.
Mar 09, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Gateway flat LCD dead
I'm not sure if your referring to the lcd monitor (gateway brand) or a laptop's lcd screen not working anymore.
1. if it's an lcd monitor...
a. test monitor in a different pc before assuming the problem is the lcd screen
b. replace the monitor if after testing monitor is in deed the item failing.
2. if it's the lcd screen from your gateway laptop.
a. you may be able to attach a regular analog monitor to the paralel port on your gateway.. test and see if the monitor that you attach will give you a picture (you may have to toggle with some some keys on your laptop keyboard to make have the signal going to the "externa" or attached monitor.
if the other monitor does not work either.. you video controller on your motherboard on your laptop may be failing and you may not have other options that to replace your laptop.
b. if the external/attached monitor works.. very likely the problem is the lcd screen for that you need to get a replacement and you may have to contact gateway to find out about pricing (or places to send your laptop for service if you're still within warranty). if you have an old laptop you may have to considere simply replacing the unit as buying a new lcd screen may very likely be more expensive than the same working laptop.
Oct 02, 2008 | Computers & Internet
Philips LCD Screen no display
Sounds like either your video is out on your computer or the monitor is bad. Does the monitor work on other computers? Will another monitor work on your computer? This is the only way to figure out if it is the monitor or the video card.
May 28, 2008 | Gateway FPD2275W LCD Monitor
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Celestron 44345 Microscope Logo
54 people viewed this question
Top Celestron Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Celestron Science and Laboratory Expert? Answer questions, earn points and help others
