Question about Cell Phones
Set up speed dial GT-E1200 - Cell Phones
I cannot find how to set up speed dial on this phone
Yup, you can set a maximum of 8-speed dial entries.
1. From the main menu, select Settings > Phone settings > Keypad > Numeric keys.
2. Highlight the key with which you wish to assign the speed-dialing number (from 2 to 9), pressEdit > Contacts.
3. Scroll to choose a contact you want to assign from Contacts and press OK.
Oct 23, 2015 | Tracfone Wireless Alcatel A392G...
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
Samsung gt-e1200 freeze
You can get the unfreeze code for your Samsung E1200 phone from SimpleUnlocking.com and unfreeze your phone from Network lock easily.
Apr 01, 2014 | Samsung GT-E1200 Unlocked Mobile Phone
Unlock code for samsung GT-E1200 please
If you want to unlock your Samsung GT-E1200 mobile phone from the network lock,you can get network unlock code from Onlinegsmunlock.com at reasonable price by specifying the details like country name,current network provider and IMEI number.
Sep 04, 2013 | Nokia 6600
Setting up speed dial on Samsung gt e1200
Setting up speed dial on the Samsung gt-e1200t
i got it for my mom...... but am not able to set spped dial can some one help me on that
Apr 16, 2013 | Cell Phones
How do you set up speed dial on the LG OPTIMUS cell phone?
From the LG Optimus S Manual:
Assigning Direct Dialing Numbers
Speed dialing, as available in other feature phones, is
not available. However, you are able to directly save a
contact to your Home screen.
To set a contact as Direct dial:
1. Press (Home Key) >(Menu Key) > Add > Shortcuts > Direct dial.
2. Tap a contact from your Contact List. The contact
will be shown on the Home screen.
Direct Dial-
Simply tap the contact on the Home screen.
Jan 04, 2011 | LG Cell Phones
CECT KA08-how to set up speed dial?
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To call the number from your speed dial list, click on the "Phone dial" icon, and hold the number down. For example, is the number 2 is home, hold 2 down until you see it dial and there you have it.
Hopes this helps
Jul 29, 2009 | Dual Electronics CECT P168 Cellular Phone
How to set a speed dial and delate old speed dial no
Just figured this out (though a lot of people seem to have tried giving an answer without seeing if it works.
Setting speed dial numbers doesn't allow you to choose one for the voice mailbox. Go to Messages -> Voice Mailbox Number (option 12). There you can change the number.
May 21, 2009 | Nokia 1100
STEPS NEEDED TO PROGRAM SPEED DIAL
For speed dial go to Main Menu >> settings >> initial setup >> Speed dial >> Phone Memory.
Than transfer numbers which you want to assign as speed dial in Phone memory.
Goto particular contact and edit the number and assign it as Speed dial.
May 20, 2009 | Motorola Mobility RAZR V3
Cell Phones Logo
558 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
