Question about Summagraphics SummaSign Pro T610 Printer
My Machine D610 Pro cutting round the edges of the letters. it does not cut perpendicular corners
How to insert sim
sim card has cut edge on one corner.
this side goes in forward.
cut edge is always top left corner.
SIM logo is top of sim card,
Mar 27, 2017 | Cell Phones
How do I cut up a large mirror?
Essentially the same as cutting glass. Get a glass cutter with a new sharp wheel. Practice on a piece of scrap glass the touch. Firm but not too heavy then make a smooth stroke along a straight edge to guide your cut.
Put a t' thick board under the line to be broken with the board to the left of your intended cut then make a push down on the glass to the right of the break line. If you have made a good continuous scribe line in the glass completely along your cut line it will snap cleanly into your desired two pieces. Repeat until you have the sizes you want. It will only break in straight lines in this method.
Us a torch to burn the edge corners to keep them from cutting you. Just heat it long enough to round the sharp edge.
Jul 02, 2014 | Home
How can above ground pool be repaired
It sounds like the hole is relatively small. You can make a patch using a piece of sheet metal or a piece of flat aluminum which you can purchase at Lowes or Home Depot in the hardware dept. Use sheet metal if the metal surround is metal. Use aluminum if the surround is aluminum. You can tell which is which by taking a magnet and touching the metal. If the magnet sticks, it's metal not aluminum. Cut the patch using sheet metal shears to a size that is 4 inches by four inches larger than the hole. Then you'll have two inches on each side of the hole. You are going to need to put the patch on the inside of the metal, between the liner and the metal surround. This so the hole edges won't tear the liner. When you cut the patch, round off the edges so there are no sharp edges. Take duct tape and cover the edges of the patch. Place 1/2 the width of the duct tape and apply it to one side of the patch and fold the other half over to the other side. You can cut a round patch, but a square or rectangle patch will be easier. Just cut the corners round. Purchase a small tube of silicone sealant ( when you but the patch material) and apply a bead around the patch edges and in the middle. Then affix the patch over the hole. Wipe off any sealant that ozzed through the patch so it doesn't bond to the liner.
Jun 01, 2014 | Karcher 2500 PSI Pressure Washer
Hello, I am having a problem with a newly bought HP deskjet 2050 all in one; when scanning some of the documents end up with ~1inch cut off even though they are standard letter size. Any suggestions?
Make sure you are placing the page in the scanner properly, most will indicate what corner/edge the scanner begins scanning from, you may also try checking the settings for the scanning software to make sure its set to letter, or try setting it to legal if its already set to letter.
May 29, 2011 | Office Equipment & Supplies
I can't get my cricut to cut out the whole letter. it cuts part of it but not all of it
I need more information. Are you using Cricut Design Studio or cutting just from the cricut itself. If you're cutting from Design Studio then you need to make sure your letter is within the space of the mat. If there is some hanging off the edge or past the cut line then it will skip over it and not cut it.
Feb 15, 2010 | Provo Craft Cricut Disney Font Cartridge
When cuuting crown molding for an inside corner cope on a compound miter saw ,what degrees do i set the saw
Hello. thanks for choosing fixya. Here is the best way to do an inside corner:
For an inside corner joint, square-cut the first piece of molding and **** it tight into corner.
1. Miter-cut the second piece to 45 degrees.
2. Highlight the leading edge of the molding with a pencil.
3. Cut along leading edge with a coping saw.
4. Smooth the cut edge with 100-grit sandpaper to create a tight joint
Nov 10, 2009 | Cars & Trucks
Cutting resin tile
You need a tile saw that uses water to prevent sparking. Home Depot, Lowes..........<$100
Apr 24, 2009 | Daltile Bathroom Accessories Resin Soap...
Plasma cutter started cutting at an angle even when held perfectly perpendicular. New consumables were put on, same amperage, same air pressure. I'm stumped!
did you put all new consumables in ,sounds like there is still old one there.make sure nozzel is put back together right.I have worked on welders and plasmas for years,the torch head is very tempermental.
Mar 01, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
The picture is round
No my freind, im afraid that you have bad waveshaper capacitors in the vertical sweep circuit in your TV set. This is not an adjustment. you should have a pro assist you with the repair of this set as it is dangerous because of the high voltage inside these sets.
Sep 24, 2006 | Sony KV-27S42 27" TV
Summagraphics SummaSign Pro T610 Printer Logo
16 people viewed this question
Top Summagraphics Office Equipment & Supplies Experts
k24674
Are you a Summagraphics Office Equipment and Supply Expert? Answer questions, earn points and help others
