Question about Apple Computers & Internet
Macbook repair parts - Apple Computers & Internet
How fix motherboard after water get inside MacBook Pro A1425? dont startup!
Dammage caused by water only can be limited by a special service centre. By heating the system only will have more damage. And even with a scheme you won't be able to repair the macBook. You could try to order the part that is damaged. To see how to open an macbook and how to replace parts, goto ifixit.com. They did lots of repairs. There are moors sites where you can see how to opener (and close) a Mac, but star with them.
Jun 18, 2014 | Apple Macbook Pro Retina 13" A1425...
Over powering issues
It sounds as though the IO Board is bad. Personally I would sell it on eBay for parts or Repair only. Take the money and buy another working unit. Or you can go here MacBook Air 13 Mid 2013 Heat Sink Replacement and check out this iFixit repair site . This is going to be a lengthy repair, but following the instructions you should be able to do it. I used the HeatSink repair, but you can choose any of the listed repairs for this item.
Feb 22, 2014 | Apple MacBook Pro Notebook
Frozen up just the circle of death spinning
listen to the hard drive, does it make a repetitive read access sound. if so i would assume your hdd is broken somebody has to open the Laptop and replace the hard drive and re-install your OS. If you want to pay to have somebody do it for you there is a third party Macbook Repair Service. However, if you want to do it yourself, the part is available on ebay. Here's an Macbook Repair guide. Maybe a tech savy friend can do it for you.
Jan 19, 2011 | Apple MacBook Pro Notebook
The left speaker of my Macbook air produces a cracking sound when in use
something could have gotten into the speaker and touch the membrane hence the crackling when the membrane moves around.you can try to blow it out with a compressed aire can. if that fails, would assume your speaker is broken somebody has to open the Macbook and replace the part. If you want to pay to have somebody do it for you there is a third party Macbook Repair Service. However, if you want to do it yourself, the part is available on ebay. Here's an Macbook Repair guide. Maybe a tech savy friend can do it for you.
Brightness in corener of screen
that's very little informatino but it sounds like the screen may need to be replaced., if you want to do it yourself, the part is available on ebay. Here's an Macbook Repair guide. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there is a third party Macbook Repair Service.
Jan 10, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook screen power up
An alternative way is always try to repair it yourself. There are Macbook Repair Guides that show how to open an Macbook. Watch out for the ribbon cables, those tear easily. Replacement parts are usually available on Ebay. There are third party services that can do it for you Mac Repair NYC.
Dec 27, 2009 | Apple MacBook Mac Notebook
Vertical lines that are shading the screen of my macbook pro
Most likely a broken screen. If the lines change when you twist the screen, defintely a broken screen. If you want to replace it yourself, there are Mac Repair Guides that show how to open a Macbook. Watch out for the ribbon cables, those tear easily. Replacement parts are usually available on Ebay. There are third party services that can do it for you, like Mac Repair NYC.
Dec 26, 2009 | Apple MacBook Mac Notebook
My macbook air think that there is a headphone in there
An alternative way is always try to repair it yourself. There are Mac Repair Guides that show how to open an Macbook. Watch out for the ribbon cables, those tear easily. Replacement parts are usually available on Ebay. There are third party services that can do it for you, like Mac Repair NYC.
Dec 17, 2009 | Apple MacBook Air
My macbook is frozen with the folder icon showing on a blank screen with a question mark on it? Help
It sounds like your MacBook can not find the system software to boot up. This is often a sign of a hard drive going bad. Try booting from the CD/DVD that came with your MacBook and running Disk Utility.
You can also refer to this article:
http://support.apple.com/kb/TS1440?viewlocale=en_US
I hope this helps.
Nov 16, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
What is the best mac repair shop in NYC? (need to replace harddrive of a macbook pro). Tekserve was pricey and slow last time.
Go to Macbook Repair, it's a service in NYC with good turnaround time. There are also free Macbook Repair guide that show you how to fix it yourself. The part is on Ebay.
Nov 12, 2009 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
22 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
