Question about Konica Minolta PagePro 1380 MF Laser Printer
Scanner can't not install and can't run - Konica Minolta PagePro 1380 MF Laser Printer
Microtek Scanner thinks it's busy when it isn't
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
May 05, 2017 | Microtek MRS-1200X6U ScanMaker X6 Flatbed...
New driver will not install
I've had this problem several times with Windows 7. Google a piece of software called CCleaner, download, install and run it. It removes registry problems, bad installs and other extraneous fluff, speeding up your machine, preventing malware attacks and making fresh installs easier. That should clear out the gunk files that are stopping the new drivers from installing. (Between running CCleaner and installing the new drivers, though, I strongly recommend restarting.)
Aug 31, 2012 | Xerox Corporation DocuMate Sheetfed...
I can't install my Documate 632 on my Dell laptop running Win 7 64 bit. It was working in the past, but quit working. I uninstalled all associated software and started over. It just won't install,...
For that first you need to uninstall old driver and software with revo uninstaller. Click here Download from above link and install then uninstall old driver and software with it. Also go to device manager right click on my computer then click on property then ->device manager uninstall all usb drivers then it will automatic install all usb drivers download driver from your printer's manufecturer web sites then install. Make sure there is not any incompatible driver or software on computer. Let me know if you need further assistance. Thanks for using FixYa..
Aug 18, 2011 | Xerox DocuMate 632 Scanner
I have downloaded the scanner software for the canon CanoScan N670U more than once, but it is not opening or running on my mac.
This was a problem with Mac's and this scanner (are you using 10.3 OS)?
Try unplugging the scanner then replugging it in, sometimes after the mac sleeps and is woken, the scanner will not be recognised (happened on XP and Vista PC machines as well)
also try using image capture on the mac rather than the canoscan toolbox software.
If you want to give installing the drivers and software another go, download the software and driver remover tool from canon's site before re-installing
Jul 27, 2011 | Canon CanoScan N670U Flatbed Scanner
Scanner doesnt have a driver for windows 7
This may help. Depending on your version of windows 7 you may be able to run Windows XP as a virtual machine and still user your scanner under XP Mode. You will have to install the XP driver for your scanner on the XP virtual machine running on your Windows 7 computer.
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software.
HERE is the direct link to instructions on downloading and using XP Mode on Windows 7
Jul 18, 2011 | Office Equipment & Supplies
CANNOT INSTAL CANON n1240U SCANNER ON WINDOWS 7
Your scanner model is not supported on windows 7.
Jun 07, 2011 | Canon CanoScan N1240U Flatbed Scanner
Hoe to install canon d646 u ex scanner to window xp
You can download the driver for your scanner from Canon here : http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_d646u#DriversAndSoftware Simply select windows XP from the pull down operating system menu, then click 'drivers' and download the driver.
Next, make sure the scanner is unplugged from your system, and run the driver install program, once it is finished, or when prompted by the driver install, plug in your scanner and it should be recognized by the system.
May 29, 2011 | Canon CanoScan D646U Flatbed Scanner
How do I install the canon scanner into my pc
The User Uuide comes together with the Scanner, and it comes with the driver and software that you must run on your PC to start all things out.
May 27, 2011 | Canon CanoScan LiDE 60
Driver for windows7 x64
These instructions will make your scanner work with Windows 7:
1) Go to this link and download the official Hp 5300C WinXP 32-bit drivers
ftp://ftp.hp.com/pub/scanners/software/sj664en.exe
2) Run the .EXE
This extracts the files to the directory c:\sj664en
3) Edit the hp53sti.inf file
Find this line:
%HPSJ5300C%=SJ5300C.Par_NT,LPTENUM\VID_04E6PID_800000402ED4
Insert this line above it:
%HPSJ5300C%=SJ5300C.Usb.NT,USB\VID_03f0&PID_0701
The section should look like:
; Win2k Models
%HPSJ5300C%=SJ5300C.Par_NT,LPTENUM\Hewlett-PackardHewle76A2
4) save the file and exit
5) delete HP53STI.CAT
6) Install the driver
Open Device Manager
Find the HP Scanjet device in teh device tree (yellow exclamation mark no doubt)
Right click it
Select Properties
Select Update Driver
Select Browse my comptuer
Select 'Let me pick'
Select 'Have disk'
In the dialog, type c:\sj664
Two unsigned HP Scanjet 5300c drivers will appear
Click on the top one
click next
it will tell you to reboot
7) reboot your PC
8) after rebooting, try it out!
I found this worked for me in PrecisionScan 3.03 TWAIN mode only. The HP-WIA part is broken in this scenario and does not appear in the WIA manager GUI at all.
Regards
j0lx
XP X64 Instructions
This is modified from a vista post, so most of the credit goes to that post that helped me make it work on xp x64.
Go to this link and download the official Hp 5300C WinXP 32-bit drivers to use with x64, the one posted on hp's site does not work.
2) Run the .EXE and then cancel the install, don't install the software, haven't been able to get it to work.
4. Find this line:
[Manufacturer]
%Mfg%=Models
5. Change it to all of the following, all 6 lines:
[Manufacturer]
%Mfg%=Models,NT.5.1, NTamd64
[Models.NTamd64]
Don't change anything else.
Save.
6. delete HP53STI.CAT
Go to device manager and update driver or add new hardware
select the directory these files are in
and it will install or select the scanner from the list.
now install a second party scanner program and it will work the one that comes with the installer for hp doesn't work.
so any second part scanner program should now work with the drive that this installs.
Jan 24, 2011 | HP ScanJet 5300C Flatbed Scanner
Konica Minolta PagePro 1380 MF Laser Printer Logo
16 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
