Question about Health & Beauty
Im looking for a good curling iron that actually works and will make my straight hair look good.
    Habit-Forming:
    New Friend:
  • 21 Answers
I was impressed with a quality construction of the actopp curling iron. The material is nice and high grade. This is not one of those cheaply made straighteners or gimmicks that will break after several uses. This thing is definitely going to last a long time.I'm not very good at hair curling and this product is so easy to use.love it! Curling Iron best hair curler shop for top women beauty products fashion jewelry and more
Posted on Sep 18, 2017
    Habit-Forming:
    New Friend:
  • 39 Answers
My favorite is a Conair curling iron. It delivers curls the way you want, and it is also very fast. Beau Clinics Non Surgical Cosmetic Treatments Bournemouth
Posted on Apr 12, 2016
    New Friend:
    Problem Solver:
  • 14 Answers
I have a Instant Heat 1 ½" Curling Iron by conair and it won't curl my hair. I've never use a curling iron this big? Any ideas?
Try putting styling gel or hairspray that is heat resistant in your hair first before curling it. but make sure products are for heat and styling first so it wont burn your hair! I have very fine hair that is straight as an arrow, and very hard to curl so before i use any curlers or curling irons, i put styling gel or mousse in it first then once I brush it out spray it again to hold the style
Mar 29, 2017 | Conair Health & Beauty
Tip
How to avoid damage your hair when using a hair straightener
1. Choose a hair flat iron depend on your hair type
The plate of a flat iron can be made by different material, while some materials will straight hair in a single pass, others might require more effort. So, before you go out and buy a straightener, you need to know which plate material suits your needs.
2. Go for Adjustable temperature Controls
No matter what type of material an iron has, it can malfunction. So, always invest your money in a straightener which has low, medium and high temperature settings. Afterward, to give your hair your favorite styles, try to keep the heat as low as possible.
3. Choose Size wisely
If you have short hair, you might want to go for a smaller iron. Conversely, only if you have extremely thick hair than going for a larger iron.
4. Fully Dry Your Hair
Unless you are using a wet iron, it's imperatively you fully dry your hair before ironing them. For, if you have wet hair while ironing, boiling the moisture out of them might do serious damage.
5. Use a heat protectant
Better be safe than be sorry. You don't want your hair to lose too much moisture while ironing. So, you might want to apply a heat protectant which will retain moisture in the face of excessive heat.
6. Don't heat one section for too long
While ironing hair, it is best that you divide them into different parts. Afterward, straighten each part for a specific time period which shouldn't be too long. For example, if you are using a flat or curling iron, it is essential that you never heat a single section of air with it for more than 5 seconds.
Source : http://selectedo.com/best-hair-flat-irons/
on Sep 29, 2017 | Health & Beauty
How to get Braun curling iron to heat?
Delilah, if it is a new curling iron and you plug it into a known good working outlet and does not heat up, it is defective. Return it to store for replacement or refund. If it is older and out of warranty, it is probably burnt out limit switch or may need rewired with new plug and cord(probably not cost effective, unless you can test and change)
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix broken curling iron Hot Tools repair
5 Troubleshooting Tips for Curling Irons
Hair Curler Repair How to Repair Small Appliances Fix It Club
The Beginner Guide to Repairing Curling Wand At Home
Aug 21, 2016 | Braun Irons
How can i gett my hair curly with no heat?
You can use curlers for that and manually curls your hair.
Nov 14, 2014 | Health & Beauty
Amika curling wand gives me err
I have the same problem. On the display it shows Err which is error i think. Can someone help us please?
Dec 20, 2013 | Amika 3P Set With Straightener &...
Anyone got good advice how I can avoid getting a hair iron burn?
Here's a tip that I find really helpful - stick a thin plastic comb between your scalp and the curling iron. It will stop the iron from getting too close to the scalp.
Feb 20, 2013 | Health & Beauty
What do the different sizes on hair irons mean?
The different sizes allow you to create different looks, so you have to bear that in mind before you buy. If you want loose curls and beachy waves then go for an iron that is about 1 to 2 inches in diameter. If you want smaller, tighter rings then go for one that is between .75 and 1 inch in diameter.
What's a good hair curler for fine hair?
I have fine hair and could never get it to hold a curl, let alone a wave. But I am finally able now that I bought the Hot Tools Ceramic professional curling iron. I am really happy with it!
Feb 04, 2013 | Health & Beauty
What types of hair irons are there?
The main types of hair irons are;
Curling irons - they create a curl or wave in the hair
Straightening irons - flatten or straighten the hair
Crimping irons - create a look similar to crimps left after braids are removed.
Jan 10, 2013 | Health & Beauty
Health & Beauty Logo
1,677 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
