Question about Adhesives, Coatings & Sealants
What's a good glue for children to use?
    Guru:
  • 269 Answers
Elmer's Glue is the best. They have both tubes and glue sticks and are non toxic. Most arts and crafts teachers use Elmer's.
Posted on Jan 10, 2013
The little girl's room should hang what murals are suitable?
The murals can let the children learn a lot of knowledge, of course, also allow children to feel good. You can hang some landscapes murals allow the children to think of the world outside. Also suitable for hanging some cartoon murals, letting the children to feel that someone paly with her.
Jan 04, 2013 | Cell Phones
My Dremel max won't start
Check and replace brushes as necessary. Also, check that the actual electrical switch is functional. I had to add a drop of crazy glue on the tip of the interior plastic handle housing that supports/puts pressure on the electrical switch to keep it in position. The off/on thumb slider actually extends well into the housing and activates the electric switch by moving back and forth. Over time, the plastic wears and does not plunge the on off switch button. A drop of glue on the tip of the plastic post extends it & causes enough pressure to make the electric switch to function again. Brushes (filed to fit) and glue = good as new Dremel :o)
Dec 08, 2012 | Dremel Multi Max Kit
I bought a Surebonder Fine Tip Hot Glue gun (small, for crafting) about less than 2 months back. It was fine at first until it stopped squirting melted glue and i had to manually push the glue stick from...
My guess is that you left the gun plugged in too long for the amount of glue that you were using. If you are using it for a good squirt every minute or so, you can leave it plugged in, but if your leave it plugged in too long while using too little, then the heat works it's way back up toward the back of the glue stick. First thing that happens is the glue-advancing trigger stops working because the advancing mechanism can't push against the softened glue stick. Leave it run even longer and it melts further back. Then when you turn it off it cools, but the melted glue is now in places it shouldn't be. If you take it apart you might be able to scrape and pry all of the once-melted glue out of it, then you would be back in business. Good luck!
Aug 27, 2012 | Crafts & Hobbies
My rear defogger doesn''t work on 2003 monte carlo
check the wires where they connect and plug in on both corners of rear window...sometimes they break off and lose contact ....they can be reglued on using a special glue that will conduct electrical current through it...can be found at most auto parts srores...good luck....Lee
Feb 19, 2012 | Chevrolet Monte Carlo Cars & Trucks
Tried flexing my driver side mirror Fri & the connector at base of the mirror broke. Had to hold onto it all the way home! Friend says, [?] unplug it, replace it w/ a temporary mirror, look for a...
I would let someone duct tape it to the car temporarily. Tape & glue can be removed with cleaner later on and you need to operate the vehicle. That will give you time to get information from all sources and make the correct decision.
Gary
Sep 04, 2011 | Car Audio & Video
Rockaverb 50 amp head. 1/4 inch plug tip broken off and stuck in 8 ohm socket. How do I open head & casing to remove tip. Are there any diagrams available online that show correct procedure.
actually there are a few ways of doing this that require no disassembly ( and i better get a good rateing for revealing these secrets haha ) check it out. take a Q-Tip and break off one of the fluffy heads. Apply some super glue to the end you broke off and shove that into the 1/4"jack and essentially glue it to the qtr inch tip. let this sit for a second and pull. should come right out IF NOT you can also try to find a screw ( usually a wood screw ) and you can thread that into the hole of the tip of the connector. if this doesnt get it out post back so i'll know and i'll walk you through how to remove the chassis and pcb's safetly. good luck!
Sep 04, 2011 | Orange Amps Orange Rockerverb 50 MK II...
You people are not good, you are charging money from little children.. We are not ready to download these basted games.. Go to hell Thanks Isha Bisht
I suggest you don't buy this game, as there doesn't seem to be anything anyone can do to change your outlook on the company producing them. I'd search around for a company that isn't "charging money from little children." var fctb_tool=null; function FCTB_Init_ca31650d11374647b26d58da78291cc3(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_ca31650d11374647b26d58da78291cc3(document['FCTB_Init_9c0386c462f6475eac4c4366d90dd63e']); delete document['FCTB_Init_9c0386c462f6475eac4c4366d90dd63e']
Aug 18, 2011 | Barbie As Sleeping Beauty for Windows,...
How do I turn on my MSI laptop, model #MS-16GN? It's my 13 year old daughter's and I need to monitor.
If you mean set up parental controls, you need to have an account on the laptop under your name with your own password (the next bit s taken directly from Microsoft)
Open Parental Controls by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, and then, under User Accounts, clicking Set up Parental Controls.? 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click the standard user account for which you want to set Parental Controls. (this will be your daughters account)
Under Parental Controls, click On.
Once you've turned on Parental Controls for your child's standard user account, you can adjust the individual settings that you want to control. You can control the following areas:
  1. Web restrictions. You can restrict the websites that children can visit, make sure children only visit age-appropriate websites, indicate whether you want to allow file downloads, and set up which content you want the content filters to block and allow. You can also block or allow specific websites. For more information, see Limit the content that children can view on the web.
    Time limits. You can set time limits to control when children are allowed to log on to the computer. Time limits prevent children from logging on during the specified hours and, if they are already logged on, they will be automatically logged off. You can set different logon hours for every day of the week. For more information, see Control when children can use the computer.
  2. Games. You can control access to games, choose an age rating level, choose the types of content you want to block, and decide whether you want to allow or block unrated or specific games. For more information, see Specify which games children can play.
  3. Allow or block specific programs. You can prevent children from running programs that you don't want them to run. For more information, see Prevent children from using specific programs.
With XP, all you can do is set up content adviser, which is a bit limited
To do this: Control panel / Internet options / Content / Content Advisor / Then in the box that appears, set the level of safety
Jul 27, 2011 | MSI M670 Notebook
My question is the glue that came with the foam plane, I'm new at this so forgive me . I made a small repair about 5-6 hours ago and the glue is still tacky, does it ever do its job? just wondering.
Hi, The glue is not doing what it's supposed to do. Try using a different glue. Contact cement is a good clue. Note: do not use strong instant glues they will melt the foam.
Jun 29, 2011 | RC Toys
My kazuma meerkat starts but wont keep going for long whats up with it
It's possible your ATV was recalled. Maybe take a look at these lists of recalled ATV's to see if yours is on there: Adult ATV's & Children's ATV's & Other Ride-Ons. If yours hasn't been recalled, you can also add it to an Items I Own account, and you'll be notified if it gets recalled in the future.
May 24, 2011 | Cycling
Adhesives, Coatings & Sealants Logo
354 people viewed this question
Top Adhesives, Coatings & Sealants Experts
David Payne
David Payne
Richard Piatek
Richard Piatek
Are you an Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
