Question about ViewSonic VA1912w 19" LCD Monitor
Viewsonic monitor shuts down
But if i press any key on the keyboard it comes back again. it cant be power saving as my setting in the control panel -power options it sas power off as never. please advise
  • 153 Answers
Try check your screen saver setting, it might be the time of screen saver to appear when PC not used, screen saver might be in blank.cheers.
Posted on Jan 22, 2009
I have a Compaq keyboard that has a half moon on the top left of it and I hit it and my monitor went blank. How do I get it back
Reboot the computer in Safe Mode by pressing F8 at boot up and selecting Safe Mode. Then go to Start->Control Panel->Keyboard. Here you will find settings of this keyboard. Disable the sleep mode. And your monitor will come alive. Whenever you have any problem you must first use the control panel and try your hands at DIY. But do remember what you did in what sequence to undo it later if need be.
Nov 17, 2009 | Compaq Keyboard
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Screen goes to sleep after "no signal" message
If you do not move the mouse or press any key on the keyboard it could be just going into video power save. Confirm it by moving the mouse or pressing a key on the keyboard. If the monitor comes back on, adjust the power settings in control panel and change the time for the "turn off display" to a more suitable setting.
Dec 31, 2008 | ViewSonic VA1930WM LCD Monitor
No Signal message
This is a message the monitor displays when the video cable is disconnected or the computer has no video output. Could be the computer is simply entering power save mode. Does the screen come on when you move the mouse or press a key on the keyboard?
Dec 28, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Sleep mode on a dell monitor
Hold down the function key on your keyboard (lower left hand side of your keyboard between the control key and the windows key) and the F8 key simultaneously. This cycles through all monitor set up modes.
Nov 22, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Monitor/display doesn't come back on
Under the power saving options in the control panel you can have the laptop set up the way you want...under the advanced settings you can select when i close the lid "do nothing"
May 07, 2008 | Dell Inspiron B130 Notebook
Monitor not working
If shutting down your laptop and restarting it didn't work and you still have a black screen on your laptop, You may have to when your computer first starts on the first logo press F2 or delete key until you get into you Bios, Reset Bios to Factory Default setting and press F 10 should save setting and you monitor should be back up and running. If that don't work get back to me, But I think I will work for you.
Dec 09, 2007 | Compaq Presario 2100T Notebook
Dell E173FP stuck in power save mode
Just had the same problem... what worked for me was simple. Unplug the cable from the monitor, hit the power button a few times until Dell screen poped up with a few color bars because it knew it was no longer connected to a PC. Then plugged the cable back in and all was fixed.
Oct 13, 2007 | Dell E173FP 17" LCD Monitor
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
ViewSonic VA1912w 19" LCD Monitor Logo
98 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
