Reset gateway n214 cmos
Reset to factory default
5 Suggested Answers
ve3wtj
  • 147 Answers
SOURCE: get error 323 - restore
Once you've reset it to factory defaults, you'll probably need to establish your initial connection to it using a Cat 5 cable - possibly crossover. Then you can visit it's internal web page (address in manual) to enable WiFi, etc.
What model was that?
Posted on Sep 18, 2008
SOURCE: Cannot reset to factory defaults Thomson TG585
You need press the reset button at least 15 seconds
Posted on Jul 17, 2009
SOURCE: how do I reset an Intel Wireless Gateway
You can reset it with RESET button it is in back side of router press It for 10 seconds.
Then connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Posted on Aug 31, 2009
SOURCE: Gateway gt5220 has cmos checksum error - defaults loaded
Open the cpu cabinet cover then pull cmos cell from motherboard for 10 minutes then all settings defaults.Then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then set bios settings.Let me know if you need further assistance.Thanks for using FixYa
Posted on Nov 19, 2011
How do i open the tray
There is no N214 Gateway laptop. Do you mean the NV series?
Feb 27, 2015 | Gateway N214 Laptop
Whay are the power lights flashing?
I don't believe there is a N214 Gateway.
Jul 09, 2014 | Gateway N214 Laptop
Factory reset
Most PC's during boot up you can hold the Del key or F2 key to enter the bios. Each bios is different but most have settings that allow you to set the system to the optimum or default (factory default) setting.
However be very careful what you change in the bios.
Record the steps so if something goes wrong you can undo it should the system not run or error out.
Most motherboards have a Cmos (Reset).
This is a jumper with pins 1,2 and 3. The jumper is usually on pins 1 and 2. To reset the Cmos to factory defaults pin the jumper on pins 2 and 3 for 2-3 seconds. (Machine OFF power unplugged!! Before you do this! You have been warned) After 2-3 seconds put the jumper back on pins 1 and 2. Plug the PC power cord up and start the machine. Laptops do not have this. Also note: Cmos is NOT the Bios.
Hope this helps good luck and be careful in the bios.
Mar 31, 2014 | E-Machines eMachines Desktop PC
FACTORY RESTORE WITH
The simplest and quickest way is to take the Cmos battery out.
Wait 10-15 min. Then re-insert this should put the system back to defaults. You may also have to Rest the Cmos.
Find the Cmos reset jumper on the Motherboard. Jumper should be on pins 1 and 2 (default). Put jumer on pins 2 and 3. Do this with the Power off and plug pulled for outlet. wait 10-15 sec and place the jumper back on pins 1 and 2. Plug machine in and restart.
Image here for reference. (I'm using this image alot today!) :)
When prompted to set a password,
You can input a new password or leave it blank.
Good luck hope this helps.
Mar 25, 2014 | Acer Gateway One ZX6980-UR308 All-In-One...
Reboot problems
Hi Dear,
The problem you discussed is hardware related, IT has to do with the cmos battery or the Sata cable.
Disconnect/Connect CMOS battery and reconfigure BIOS settings again based on defaults
- Replace "ALL" SATA Cables and reconnect all drives
Regards
Samson Ved
Oct 18, 2013 | Gateway GT5670 Desktop PC
Need to hard reset westell 7500 modem to factory defaults..cust chngd admin password and can't remember what they chngd it to and i need to get into modem
  • Note: Resetting your router to the factory defaults not only changes your router user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your router to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and encryption key.
To reset your VersaLink 7500 gateway to the factory settings:
  1. Hold the reset button on the back panel of the VersaLink 7500 gateway for 30 seconds.
    • All your settings will be lost including network encryption information and any SSID information you have entered.
    • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  2. Your VersaLink 7500 gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
Nov 05, 2011 | Westell Wirespeed VersaLink...
Need to reset CMOS setup utility in Advanced Bios Features to original sequence for a Gateway SX2800-01. Having so many problems; got recovery disks but it isn't reading properly to boot up
If iy remove the cmos battery off of the motherboard and leave it off for about 30 minutes it should reset back to factory defaults. To get to The Cmos Battery simply unplug your computer and take off the side cover. Once you can see inside look for what looks like a big button battery (watch Battery). Remove it and leave it out. Once the 30 minutes has passed put it back in a plug in the computer. All things should be good to go at this point.
Aug 26, 2011 | Gateway Computers & Internet
Password forget intel wireless gateway
To reset the IntelĀ® Wireless Gateway back to factory defaults you have to perform a default reset.
There is a reset switch on the rear of the unit. With the unit powered on, use a paperclip or similar device to depress the switch for 5 seconds. The unit will restart.
Note: After doing a default reset, the IntelĀ® Wireless Gateway will have the default user name and password of "Intel". The default IP address will be 192.0.2.1 with a subnet mask of 255.255.255.0. The default SSID will be 101. The default channel will be 11. DHCP will be enabled.
Good Luck,
Rodrick
Apr 22, 2011 | Intel Wireless Gateway (WLGW2011BRW)...
How do I reset my Gateway LT20 Netbook Series back to the factory settings?
Very simple! You need to go into Cmos for the setup which is usualy F2 on boot. Once in the setup you go to the end page whwere it asks you if you want to restore factory defaults. Simply click on it then press save and exit. If F2 does not work on the boot to access Cmos setup then look at the screen as it starts to boot and it will usualy tell you what function key is for setup. Good luck Phil
Apr 22, 2010 | Gateway Computers & Internet
VGC-RB42G flashig power light and won't power
I have had this problem if power is removed by disconnecting the power cord (in cases where nothing else works). To fix the problem:
1) remove the power cord from the back of the unit
2) disconnect the large power connector from the power supply to the motherboard
3) apply power to the power supply
4) reconnect the motherboard power connector
5) turn the unit on
- dedndave
Apr 13, 2010 | Sony VAIO VGC-RB42G PC Desktop
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
