Question about Gateway nv Computers & Internet
Reset gateway n214 cmos
Reset to factory
How do i open the tray
There is no N214 Gateway laptop. Do you mean the NV series?
Feb 27, 2015 | Gateway N214 Laptop
Whay are the power lights flashing?
I don't believe there is a N214 Gateway.
Jul 09, 2014 | Gateway N214 Laptop
My gateway N214 SCREEN GOES WHITE
just remove the RAM then puts it back or removing the battery then power it on , check it
Feb 04, 2013 | Gateway LT2021u Netbook
Gateway n214 hard disk drivers windows 7
Take a look on this webpage: Driver Update Tool for driver related problems. Wish you best of luck
Dave
Jul 09, 2012 | Gateway 7330GZ Notebook
Need to reset CMOS setup utility in Advanced Bios Features to original sequence for a Gateway SX2800-01. Having so many problems; got recovery disks but it isn't reading properly to boot up
If iy remove the cmos battery off of the motherboard and leave it off for about 30 minutes it should reset back to factory defaults. To get to The Cmos Battery simply unplug your computer and take off the side cover. Once you can see inside look for what looks like a big button battery (watch Battery). Remove it and leave it out. Once the 30 minutes has passed put it back in a plug in the computer. All things should be good to go at this point.
Aug 26, 2011 | Gateway Computers & Internet
I forgot my gateway model ML6230 bios password, i need a new password for it (reset the password).
A method you can try if you don't have a password reset software is by removing the CMOS battery. Remove the CMOS battery then turn the computer on. The system BIOS will be reset and password will be removed. Then you can put the battery back in. Click on this link for the Gateway ML6230 Notebook PC Manual. Check page 36 for CMOS battery removal instructions.
http://support.gateway.com/s/Mobile/Q106/Oasis/8511725_Service.pdf
Mar 21, 2011 | Gateway ML6230 Notebook
How do I reset my Gateway LT20 Netbook Series back to the factory settings?
Very simple! You need to go into Cmos for the setup which is usualy F2 on boot. Once in the setup you go to the end page whwere it asks you if you want to restore factory defaults. Simply click on it then press save and exit. If F2 does not work on the boot to access Cmos setup then look at the screen as it starts to boot and it will usualy tell you what function key is for setup. Good luck Phil
Apr 22, 2010 | Gateway Computers & Internet
Bios issue
Even if you turn off the on board graphics, the computer usually will output video until after BIOS post. Simply plug the monitor back into the motherboard video card. If that doesnt work you can actually just reset the cmos by opening the case ( make sure its unplugged) and there is a spot on the lower left where a jumper is and you can remove that to clear the CMOS. There are many you tube videos on how to do this. By doing this you will reset the CMOS to factory.
Mar 16, 2010 | Gateway GM5260 PC Desktop
I want to reset my Gateway LX6200-01 to factory settings
Hello!
If you computer can go to the system, few second or more, maybe you have trouble with heathing, and clear cmos isn´t solution for that.
Than you need good expert for repair you computer.
Oct 30, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
Computers & Internet Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
