Question about Sanyo DS25390 TV
Sanyo DS25390 Vertical problem
Need part number for the verticle output IC in a DS25390-02 chassis. Also any common capicators that cause foldover in the vetical circuit? Thanks :-)
  • Jack Ewer
    Jack Ewer Aug 11, 2007
    Hi finally got the Sanyo DS25390-02 TV fixed. I replaced C502(220uf/35V) , C516(4.7uf/50V) & C503(3.3uf/50V). The ESR on all 3 of these caps was way out of specs. The verticle IC501 is a LA7841 (NTE 7153). There are also C501(10uf/50V)& C504(2200uf/25V) in this circuit which measured good so I left them alone. After several days the set is playing great. Hope this helps someone else, Happy Trails....Jack
  • 139 Answers
Jack,Did the Vert Ic have Broken conns around the legs?
Posted on Jul 19, 2007
SOURCE:
Tv has horizontal line in middle of screen,sanyo ds25390
hi if only a horizontal line across with no video anymore, you have bad either vertical ic or no dc supply b+( vertical ic ) or no output dc coming from the ic. if it is not totally a horizontal white line and you can see a video you must check leak or bulged capacitors at the vertical section near the vertical ic. hope this can help good luck.
Oct 02, 2012 | Televison & Video
My sanyo ds20425 has a white horzontal across the screen
On most , it is caused by Vertical IC and sorrounding components
Guide on How to find Vertical IC
Look and check for cold solder joints for IC501
part number
LA7840
Resolder the pins of the IC , and replace if necessary
Let us know if you need further assistance.
Sep 21, 2012 | Sanyo DS24205 24" TV
I lost my system ic i nid part number?
I'm assuming that your TV is Sanyo DS25390.
Click this LINK. Download the Service manual, you can now determine the system IC of your TV. When you are on the link, click "Get Manual" to automatically begin the download.
Dec 14, 2011 | Sanyo DS25390 TV
Vertical deflection
You will have to inspect the pins of the vertical IC. They may need resoldered. And you may have to replace some of the capacitors in the immediate area of this IC. If you still have a vertical problem you may have to replace the vertical IC.And please check the diodes near this IC, rare but occasionally they will short out.
Aug 04, 2010 | Sanyo DS25390 TV
Picture folding over at top of screen
Verticle IC needs replaced and also the sodered connections could be bad at the high voltage transformer.
Oct 14, 2009 | Sanyo AVM-3659S 36" TV
Black screen white horizontal line help
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Sep 30, 2009 | Sanyo DS25390 TV
Question?
R483 near FBT, and R511 near vertical IC (FBT is flyback transformer) Has big red wire coming out
Apr 30, 2008 | Sanyo DS25390 TV
One White Horizontal line on black screen
replace the vertical IC problem solved
Dec 31, 2007 | Sanyo DS25390 TV
Straight line picture
If you were able to tap on the set to get it working, then it means that the solder joints on the vertical output IC are cracked and loose. This is very common on those sets. Now, the pins of the IC could be so loose that they just wont work anymore, and simply resoldering the pins of the IC will cure your problem. However, it could also be that the loose pins have caused the IC to short out inside, in which case the IC will have to be replaced and most likely a small resistor in its power supply too. If you do not have experience working on things like that in TV sets, allow a qualified tech to handle it for you.
Aug 30, 2007 | Sanyo DS25390 TV
DS25390 Verticle foldover
If you have a picture but the top is folded over, your vertical IC is probably good and you need to replace the pump-up capacitor next to the IC. When the pump-up cap (typically a 47 or 100uF 35V cap) is open then the picture will have white lines and foldover at the top. The typical vertical output IC is the LA7838, but I am not familiar with exactly which output IC your set uses.
Jul 02, 2007 | Sanyo DS25390 TV
Televison & Video Logo
171 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
