Question about Hotpoint-Ariston LFT 228A 23 in Builtin Dishwasher
Ariston model LFT 228 A/HA error code 11 and machine doesn't run
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: Hotpoint LFT 228 A dishwasher not making any sound
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Posted on Mar 12, 2012
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
Lcode 1 flashes and drain pump doesn't stop
The flash code means there is water in the base panel underneath appliance first check the support on your lower arm isn't loose then leave to dry out
Jan 01, 2013 | Hotpoint-Ariston LFT 321HX Dishwasher
Hotpoint Ariston FK 89EL.20 X/HA Electric Oven
Same error. No fix find yet. Only push on/off button 3 seconds.
Aug 11, 2012 | Hotpoint Ariston DY46 Electric Oven
Mar 11, 2012 | Hotpoint-Ariston LFT 228A 23 in Builtin...
Hotpoint LFT 228 A dishwasher intermittent draining problems. Sometimes so much water that it leaks, will drain sometimes but then water appears in the filter again, items in dishwasher sometimes
Hello, craig
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Sep 26, 2011 | Hotpoint-Ariston LFT 228A 23 in Builtin...
Hotpoint LFT 228 A dishwasher intermittent draining problems. Sometimes so much water that it leaks, will drain sometimes but then water appears in the filter again, items in dishwasher sometimes come out...
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
Sep 25, 2011 | Hotpoint-Ariston LFT 228A 23 in Builtin...
Ariston washing machine. Error code F09
Most Indesit ( Hotpoint, Ariston) machine's 'F09' decodes as ' incompatible eeprom' or eeprom error, check/change eeprom'. Sorry, whichever it is requires an engineer call ;-0(
Hopefully it might only need connectors reseating.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | Ariston Technologies Washing Machines
Fdd914 dishwasher error code A10 appears and its not in the booklet
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
Have error code F 09 appearing - are you able to tell me what this stands for? Thank you
Although you have not told us the model number, 'F09' for most Indesit (Hotpoint, Ariston) models decodes as 'eEprom error' which requires an engineer's attention I'm afraid. Sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
John C.
Apr 29, 2011 | Hotpoint Washing Machines
Hotpoint-Ariston LFT 228A 23 in Builtin Dishwasher Logo
1,271 people viewed this question
Top Hotpoint-Ariston Dishwashers Experts
Are you a Hotpoint-Ariston Dishwasher Expert? Answer questions, earn points and help others
