Question about Water Heaters
Wont stay lite
I have a reliance water heater and i cant get it to stay lite i
hold the red button and hit the ignitor it lites but it does not kick on
it did the same thing yesterday and it did stay lite
  • Dale Koehn
    Dale Koehn May 11, 2010
    thanks for your question, how old is the HWT ? do you still have the instruction manual ? are there wires running to a little disc, about the size of a dime near the view port on the tank ?
  • 10,865 Answers
I recommend contacting the company and asking them to send you a new thermocouple. This is easy to change and will most likely solve your problem. When you contact them have all of the information ready such as model #, serial #, date of purcahse etc., whatever you have. good luck
Posted on Jan 21, 2009
What pilot light assy. do I need to buy for model# 640y0rt4, water heater ??? please wont stay lit
check that the flame sensor is clean. It would be a stiff piece of wire that would sit right over where the pilot lite is. If it is dirty...it wont sense if there is a flame....and if it dosnt sense a flame....it wont let the pilot lite to turn on.
Jun 03, 2015 | Reliance 606 Series 40 Gallon Natural Gas...
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 12, 2012 | Water Heaters
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
Installed new thermocoupler heater still will not stay lite
Make sure the pilot light is hitting the thermocoupler, even when burner kicks in. Sometimes a dirty pilot tube will cause a weak pilot and it wont continuely hit the thermocoupler. I use air to clean mine. Hope this helps.
May 26, 2010 | RTO Atwood Water Heater - 6 Gal LP
Reliance gas water heater, pilot will not stay lited
sounds like you have a worn thermocouple or maybe a blocked jet
May 04, 2010 | Reliance Water Heater #6-30-YORT 30GAL NAT...
Piolet lite will not stay lite. Takes awhile to lite after it dose lite it kicks off again
Sounds like a bat thermocouple to me. Replace it they are not very expensive.
Good Luck,
Gil
Mar 01, 2010 | Reliance & 30 Gal LP Gas Water Heater
Water Heaters Logo
88 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
