Question about Texas Instruments TI-86 Calculator
How to calculate cube root on simple calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
That depends on how simple a calculator. I'll give some examples below for calculating the cube root of 8.
On a TI-86, press 3 2nd [MATH] F5 MORE F4 8 ENTER
If the calculator has a "^" or "y^x" key, raise 8 to the 1/3 power. Again, on the TI-86, press 8 ^ ( 1 / 3 ) ENTER
If the calculator has a logarithm key, take the logarithm, divide it by three, then take the antilogarithm. Again, on the TI-86, press 2nd [e^x] ( ln 8 / 3 ) ENTER
On a slide rule, place the hairline over the number on the K scale and read the cube root on the D scale.
Posted on Jan 10, 2013
SOURCE: HOW TO FIND CUBE ROOT
There is a way to do it. I believe you go into "complex" or "math" buttons. These buttons are yellow on the calculator. Therefore, to access them you must hit "2nd" then the button.
Better yet, you can also get around this dilemma another way. You can enter "the cubed root of x" by raising x to 1/3.
For example the cubed root of x = x^(1/3). It is best to place parentheses around 1/3 so the calculator knows exactly what you mean.
Another example, the "cubed root of (x + 1)" can be entered by:
(x+1)^(1/3) Note the parenteses around both (x+1) and (1/3). This applies if the radical cover both "x" and "1".
Hope this helps.
Posted on Nov 09, 2007
  • 3 Answers
SOURCE: Cube roots
You use the y^x (y to the x) key along with the 2nd function key. That does the opposite operation.
So, let's pick something we know the answer to as an example. How about the cube root of 8? We know 8 = 2 X 2 X 2, so the cube root of 8 will be 2.
Here's how:
8 2nd y^x 3 =
The display will show 2.
The three is the root you want. You can put in any number, with 2 being the square root, 3 the cube root, etc.
Posted on May 17, 2008
  • 60 Answers
SOURCE: how do I cube root a number on my ti89 titanium
To find the cubed root of say...8, then you would type this into the calculator:
root(8,3)
Posted on Nov 13, 2009
  • 60 Answers
SOURCE: cube roots on ti89
The TI-89 has one function to find whatever root you want of a number.
To find the cubed root of say...64, you would type:
root(64,3)
Posted on Nov 14, 2009
  • 7993 Answers
SOURCE: is it possible to calculate cube root or higher
To extract the roots of orders higher than 2, you can use the universal power key labeled as [Y to x]. if the exponent is an integer 3, 4, 5, 6 etc.
it gives the cube the 4th power, 5th, 6th, etc.
If the exponent is 1/3, 1/4, 1/5, 1/6 you calculate the cubic root, the 4th root and so on.
When you use it to calculate the roots, the radicand (the number the root of which you are calculating) must be positive, otherwise you may get the result as a complex number.
The syntax of the command is value [Y to x] (1/ order of root)
Ex: cube root of 27 is entered as 27 [Y to x] (1/3)
Posted on Feb 21, 2010
How to find the cube root on a calculator
Press MATH 4 to access the cube root function.
For example, to calculate the cube root of 8, press MATH 4 8 ENTER
Nov 05, 2013 | Texas Instruments TI-84 Plus Calculator
Nov 05, 2013 | Texas Instruments BA-II Plus Calculator
Radical calculation
There are limits to what the calculator can display in symbolic form, and roots beyond the second (square roots) are beyond its capabilities. Even something as simple as the cube root of 2 will be displayed numerically.
Mar 21, 2013 | Casio fx-300ES Calculator
How do i use my calculator to solve this problem 40 exponent 1/3
I assume you want 40 raised to the one-third power?
Three simple ways.
Raise 40 to the one-third power: Press 4 0 y^x ( 1 / 3 ) =
or
Take the cube root of 40: Press 4 0 2nd cube-root = (the cube-root is the shifted function of the 0 key)
or
Take the third root of 40: Press 4 0 2nd xth-root 3 = (the xth-root is the shifted function of the y^x key, located just above the divide key)
Mar 14, 2012 | Texas Instruments TI-30XA Calculator
Cube roots
The TI-89 does not have a cube root function. However, you can calculate any root simply by raising to the reciprocal of the power. For example, to calculate the cube (third) root of 125, press
5 ^ ( 1 / 3 ) ENTER
Nov 03, 2011 | Texas Instruments TI-89 Calculator
How do you calculate the cubed root of a number or 5th root of a number?
For cube roots, use the cube-root function in the MATH menu. For example, to calculate the cube root of 8, press MATH 4 8 =
For other roots (including cube root), use the xth-root function in the MATH menu. For example, to calculate the fifth root of 32, press 5 MATH 4 3 2 =
Mar 02, 2011 | Texas Instruments TI-83 Plus Calculator
How do i use the cube root function? i can find the square root function, but at present it does not seem that the calculator has a cube root function.
There's a cube root function as the fourth item in the MATH menu. The fifth item is a general root function.
Feb 21, 2011 | Texas Instruments TI-84 Plus Calculator
Finding a cube root on calculator
You can calculate cube roots by using the cube root function (the 2nd-shift of the 0 key). You can calculate arbitrary roots by using the x-root function (the 2nd-shift of the y^x key, just above the divide key).
May 27, 2010 | Texas Instruments TI-30XA Calculator
How to find a cube root using the calculator
You can calculate the cube root by raising to the one-third power. For example, to calculate the cube root of 125, press 1 2 5 y^x 3 1/x =
The y^x key is just above the 9 key. The 1/x key is just above that.
May 20, 2010 | Texas Instruments BA-II Plus Calculator
How to find cubed root on a TI-89 calculator
To find the cubed root (or any root) of a number, use the root() function.
If you want the cubed root of 125, you would type:
root(125,3)
Mar 06, 2009 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
123 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
