Vgn-fz18m bios upgrate - Computers & Internet
HAVE TRIED CHANGE THE CMOS BATTEWHAT CAN I DO NXTRY TO REMOVE BIOS PASSWORD BUT IT COUDNT WORK,?
Sony Vaio PCG and some Vaio VGN Series use the last 7 digits of the laptop serial number to calculate the bios master password. The serial number for a Sony Vaio is often located on the bottom of the laptop on a white sticker. The serial number may also be found by removing the battery and checking in the battery compartment. The link to unlockbiosrecovery.com below works on the following models:
PCG-C, PCG-F, PCG-GR, PCG-GRS, PCG-GRT, PCG-GRV, PCG-GRX, PCG-GRZ, PCG-N, PCG-NV205, PCG-QR, PCG-R, PCG-SR, PCG-SRX, PCG-TR, PCG-V, PCG-VX, PCG-X, PCG-Z, VGN-B, VGN-FS, VGN-S, VGN-T, VGN-TX1, VGN-X
I use http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php
For $20 they use the last 7 digits of the laptop serial number to calculate the bios master password and then email it to you in an hour. They guarantee it to work and you can call them if you have a question.
Sep 10, 2011 | Sony VAIO VGN-FS640W Notebook
Please advise how to reset the biose on vgn-s28gp,i try to find reset jumper but i did not find out please help. aqeel.
Not sure which key Sony used but the easiest way to reset the Bios for a laptop is to start teh computer and go straight to Bios and select to restore Default settings. All Bios setups ahve this option. It is normally the F2, Del, F10 or F12 key right after you see the initial splash screen after tuning the computer on. The only other option I can think of without tearing the system open would be to remove the power cord, the main battery and the Bios battery if you have access then put it all back. In some models you can remove teh covers from the hard drive or Ram on the bottom of the computer and get to the Bios battery to remove it. I know a lot of HP models have that so it may be an option with the Vaio.
Jun 16, 2011 | Sony Vaio Vgn-s28gp / Vgn-s380 / Vgn-s380b...
I cant remember the bios password of my notebook model sony vaio vgn-a497xp
You can reset the BIOS password. To reset the BIOS password read the information from this link.
Feb 24, 2011 | Sony VAIO VGN-A497XP PC Notebook
I upgraded my SONY VAIO VGN-C2S/H from vista to windows 7... but its not recognizing memory stick
Go on sony website and dowload the proper drivers for your machine. The old drivers from vista might not work properly in 7. I, personaly, recomand a fresh clean install in the upgrading cases. That means to format the HDD and install everything from zero. Upgrating from an OS to another by installing an update patch is not a big deal. There might remain some dirty registry wich will make the sistem running slowly.
Jan 25, 2011 | Sony for Sony VAIO VGN-C2S/G VGN-C2S/H...
How to upgrate my 845 GVSR BIOS SETUP?
You can download the bios file and the manual from here
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng
search for motherboard model number.
Be very careful while upgrading BIOS.
Jul 05, 2010 | Intel Computers & Internet
Install wrong bios on sony vaio laptop model vgn cr 353 so dont see anything in bios setup or some garbeg seen in bios cant acess bios
BIOS is gone...u need to change the BIOS IC or may be the full Motherboard...
the other option is to go to tech shop and "TRY" have ur BIOS flashed with the correct BIOS software...
Feb 05, 2010 | Sony VAIO VGN-CR305E/R Notebook
I upgrated the processor from a celeron 1.6 to a 1.8 but it is now asking for processor bios update.not sure how to do that
Since you upgraded the processor now it requires BIOS (Basic Input output system) update to get it working correctly... Tell me your computer model number so that i can paste link to download BIOS update for you which you need to download and install to get your computer working !!
Thanks ..
Sep 08, 2009 | IBM NetVista PC Desktop
Bios
just download a bios update of the web page of the fabricant, all fabricants have diferents modes to upgrate, somes need a floppy disk, others can be upgrade from windows running
Jul 20, 2009 | Dell Dimension 8300 PC Desktop
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
