Question about JVC HR-J692U S-VHS VCR
Jvc vcr Yesterday my VCR quit working. I went to set it to record using the timer. It wouldn't work. When I turned the power on to the VCR, then clicked TV/VCR the tv screen would go black. When I would turn off TV/VCR then the tv worked. I haven't been able to get the menu to come up, I can't do a darn thing with the VCR. When I turn on VCR power, it shows L --- then it will go to C0..., then it clears to nothing but zeros. HELP!!!! I need to get my VCR up and working - I am a Jay fan and must be able to record their games so that I can watch them when I get home from work; and I am also a football fan of the Saskatchewan Roughriders. It seems so ironic, the season started last Friday night and my VCR went on the fritz two days later. This does not make for a very happy momma. Oh yes, I also went and bought new batteries, thinking that was the problem, but to no avail. I would appreciate any assistance. Thank you, Marlene
  • Marlene Breti Jul 03, 2007
    I am so thankful it was something as simple as unplugging the unit - because I couldn't understand all the "big" words! Thanks so much for your reply - things are up and running and momma is happy once more.
    Marlene
    Novelist:
    Champion:
  • 254 Answers
First try unplugging the unit for about 20 or 30 seconds, to do a reset on the logic circuitry. Beyond this, the rig has an internal electronic problem. The power supply circuitry would be where to look next. If you have a voltmeter and some tech savvy, check the output voltages. There should be a +5, +12-15, & a -40 volt or so. The +5volt line must be very close tolerance, within about .2 volt. This supplies the logic circuits, and if it is wrong, operation is compromised. If by chance voltages are off, such is likely caused by one or more bad electrolytic capacitors. Digi-Key Corp. has Panasonic FC series capacitors which I generally use for replacements. Mouser electronics is another source also. Perhaps another contributor has seen this specific problem and has a better diagnosis.
Posted on Jul 03, 2007
SOURCE:
Can't get it to start Record LInk on a JVC HR-S3600U VCR.
Hi my nameis Mike Houston of DISH Network and I see you can't get it start the recordlink on you're JVC HR-S3600u VCR. As faras the DISH Network receiver goes press Menu-7 and then the tab Create Timer. Youwill see Timer Type and select VCR then the timer Frequency type, and then youwill set your VCR to the time of the recording. If you have any questionsplease e-mail me at [email protected]
Jul 31, 2011 | DISH Network ViP 211 DTV Receiver
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Can't get my new DVD/VCR to work.
I read the instruction manual one more time. It said to tune my TV to Video and voila, the VCR worked. All JVC VCR's seem to need the tv tuned to Video to play back. I had an older JVC VCR and I had to do the same thing with it.
Thanks anyway.
Jan 18, 2010 | JVC Televison & Video
VCR not timer recording, VCR will not turn on with timer
If no menu, unplug, and let it set a few minutes. Replug and the on-screen menu should appear. Reset the set-up (date, etc). I had the same experience as one of the other posters with JVC customer service telling me the menu button on the remote was malfunctioning, and I should purchase a new remote from them.
After you input your programming, be sure to hit the Timer button on your remote. If you want to change tapes or playback, you will need to hit the Timer button again (take it off Timer) for access to your VCR. Be sure to reset it to Timer afterwards, or you will not be able to record.
Feb 17, 2009 | JVC HR-A592U S-VHS VCR
Samsung DVD-V4600A Combo DVD / VCR will no longer timer record to Videotape
Storms tend to fry most delicate electronics. Quality surge protection is required.
Ben
Jul 25, 2008 | Samsung DVD-V4600 DVD Player/VCR
JVC DR-MX1S
This machine has a lot of problems. One thing that often works is to turn it off and unplug it for a couple of minutes. Then plug it in again. Then it will say "loading" for quite a while. Leave it alone until it turns itself on. Then it should be okay. If the couple of minutes doesn't work, sometimes unplugged overnight (same method) works, but then you have to reset everything.
Feb 02, 2008 | JVC DR-MX1S DVD Recorder/VCR
Programming a vcr
How can t I get the pop up screen when I apply menu. When I press menu nothing appends. I have the illico box for HD and had the videotron tech install it so I can recorded but since the menu does not work I cannot set the time or anything else on it.
Thanks
Gilles T Garceau
Dec 11, 2007 | JVC HR-A592U S-VHS VCR
How to set the vcr to record
Hi I'm not familiar with your model in particular, but normally there will be a timer button on the remote that you must press, or you must turn the vcr off after programming it for the timer recordings to be made. There should be a timer indicator on the front, either a symbol or a red light depending on the age of the vcr. If you program it, then press the timer button on the remote, the timer light should be on and the vcr will shut itself off, if it is the other type, then the timer indicator should stay lit when you shut off the machine. If that light is on, then your timer recordings should work. Hope this helps, good luck!
Feb 06, 2007 | Hitachi VTMX4510A S-VHS VCR
JVC HR-J692U S-VHS VCR Logo
219 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
