Question about Panasonic NN-S769 Microwave Oven
Change the bulb - Panasonic NN-S769 Microwave Oven
  • steve hughes Jan 14, 2013
    yes it did...Thanks
  • Panasonic Master
  • 17,129 Answers
Remove the top cover by removing the side screws of the top cover. The chamber lamp is mounted within the slit of the top and will be visible. You can remove the covers to get to the lamp. replace with the same type and thread. if the lamp has not blown it can be due to faulty switch or relay.Trace the lamp circuit to confirm the fault
Posted on Jan 11, 2013
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Screwdriver
Light
Unplug the Magic Chef microwave from the wall outlet.
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Oct 08, 2016 | Magic Chef Microwave Ovens
GE double Oven range PLT059-2 How do you access surface light bulb to change it?
There should a sliding panel of glass or plastic covering the light. Remove the glass or plastic then you should see the light bulb. If the light buld is a regular old bulb unscrew it if its a small floorisent bulb twist it so it will roll out of its sitting position. Then you can take the bulb to any hardware store to match the bulb. DO NOT PAY FOR SOME ONE TO CHANGE A LIGHT BULB....Please if this helped you post that I helped you with the correct answer so i may get credit....
Nov 17, 2014 | Microwave Ovens
How do I change the bulb in Alba TRDAB2820 radio
back-light bulb is actually LED's and these fade when the capacitors fail 4 X 470uf at 10v and 1 X 1000uf at 16v on board behind display, change all 5 and it should be ok again.
Martin
Mar 18, 2014 | Emerson MW8107WA Microwave Oven
How to change bulb
Hi
we have two vintage vacuum cleaners a 612 from 1949 and a 652 from 1959 Does anybody know how to change bulbs on the headlights ion these machines ?
Jan 07, 2014 | Emerson MW8107WA Microwave Oven
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
Need to change the light bulb. found it but can't
push in on the bulb and then turn a quarter turn counter-clockwise,its a bayonet base bulb,not a candelabra base like a typical light bulb has
Jul 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to change inside bulb
Normal procedure is to remove case cover to access the bulb.
Usually several screws on the back and some partially hidden on the front to remove. Sometimes the screws require a Torx screwdriver.
Unplug unit and avoid touching any wires.
Replace bulb with exact type.
Jan 07, 2010 | Frigidaire FMV156DC Microwave Oven
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Mar 15, 2009 | Microwave Ovens
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do you change the bulb
First, take off the cover and you will see the bulb. You must have the unit unplugged and do not touch anything else inside the unit after you take off the cover. Theres a capacitor in there that holds a big charge.. Change the bulb as you may have to go to the hardware store as it may not be a regular bulb Most are not. Good Luck
Jul 02, 2006 | LG LRM1250 Microwave Oven
Panasonic NN-S769 Microwave Oven Logo
71 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
