Question about JVC Kd-r332 Cd Mp3 Car Stereo, Dual Aux-in Front & Rear, Tuner Rapid Delivery
JVC kd-r332 settings keep resetting after unit is turned off
    New Friend:
I had this exact same problem - in my case caused by the wire that should provide a continuous feed so the unit can keep its settings actually being from the ignition switch, and the continuous feed wire being connected to the terminal that should be from the ignition switch! I had a red wire (continuous feed) and a yellow wire (ignition activated feed) feeding to the back of the unit, and all I did was to switch these over - both wires had their own connectors let into the wires a few inches from the unit so that switch over job was easy. Works as it should now, although i have a grazed knuckle as the wires leading to the plug at the back were a bit too short! Chris
Posted on Mar 12, 2013
How to reset jvc kd-r330
Detach the control panel. Check for a small hole with a reset button which can be only pushed with a carbon pen tip once to reset the unit. When the car is running keep this pressed for about 5 seconds. The unit will reset. Refer to the below web address manual page 3 for details & a diagram. https://www.manualslib.com/manual/449215/Jvc-Kd-R330.html?page=3#manual
Jan 25, 2018 | JVC Car Audio & Video
How can i save my settings on jvc kd-r446 ? every time i shut down my settings is reset
if it is resetting oon shut down , you dont have your memory wire connected to a full time power wire . full time power wire is a wire that has power even when car is off.. this is what saves your memory on the head unit.memory wire is usually yellow.
Feb 26, 2014 | JVC Car Audio & Video
I want to get jvc kd r425 pro eq manual settings
jvc kd-r425 problem is check wiring , then reset ,unit
Apr 22, 2012 | JVC Car Audio & Video
After market receiver periodically resets itself (JVC KD-DV5300)
In KD-DV5300, replace capacitor C751. Capacitors dry with age.
Feb 16, 2012 | JVC Car Audio & Video
JVC Frontloader MP3 player KD-G415 time set
turn the unit off, while on standby push and hold the select button
May 03, 2010 | JVC KD-G420 CD Player
Need to reset the clock on my JVC KD-SX650
Does this unit have RDS on it? if so switch it on and it should set your clock for you
Feb 03, 2010 | JVC KD-SX650 CD Player
Car stereo JVC KD-PDR40 lost manual can't set clock?
hi my jvc kd-pdr40 cd player keeps resetting the sound to basic with no bass everytime i turn it off
Sep 26, 2009 | JVC KD-PDR30 CD Player
JVC KD-AVX33 pairing problem
To inicialize to factory settings do: In "Setup" menu go to "others" menu, go to "Initialize" press "Enter".
With this you will loss all your customized settings
Sep 25, 2008 | JVC KD-AVX33 Car Video Player
Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
Mar 17, 2007 | JVC KD-G420 CD Player
JVC Kd-r332 Cd Mp3 Car Stereo, Dual Aux-in Front & Rear, Tuner Rapid Delivery Logo
128 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
