Question about RCA RCU4GLW Remote Control
Closed caption on. Want it off.
My dog somehow activated the closed caption. There is no CC button on the remote. RCA RCU4GLW How do I turn it off.
  • gsnark Jan 21, 2009
    You call that a solution?
  • Anonymous Mar 21, 2014
    remove cc
The closed captioned in stuck in spanish on the screen does not move how do we remove this.
Posted on Jan 21, 2009
Need Closed Captioning
If you have the original remote control, there will be a button marked "CC", and pressing it once, the closed caption funciton will turn OFF, and for an other press, it will re-appear. Now, here you are using a universal remote control. So it will be difficult to make closed caption. Try to enter its function menu by using present remote control, where you can make this funicion OFF, if you could enter into it.
Jun 02, 2013 | Insignia NS-RTV32 32" TV
How do I turn off closed caption on a RCA GUIDE PLUS GOLD GEMSTAR?
Press the "CC" button on the remote controll once. If there is no such button on the remote control, get into Menu of the TV, surf thorugh, come to closed caption optione seclect fucntion, and make Closed Caption to OFF.
Apr 09, 2012 | RCA Televison & Video
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
WE HAVE A BLACK BOX IN THE MIDDLE OF OUR TV AND CAN'T GET IT OFF WITH THE REMOTE
Black boxes in the middle of the screen are text boxes. Text is a part of the closed captioning feature either on your television or your cable/set top box. You would press the closed captioning button on the remote repeatedly until it displays cc off or something similar. Captioning might also be active on your cable box/set top box. There is normally a hidden menu on the cable box and that is where closed captioning is. You have to turn the cable box off. Yes I did say turn the cable box off. Then press the menu button on it and then the hidden menu will pop up. Then navigate to closed captioning and choose disable.
Nov 09, 2010 | JVC Televison & Video
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
Closed captioning code for an Armstrong Cable UEI controller
I cannot imagine the original person still has this issue but if you turn off the cable box, assuming it is an HD PVR, you then hit the menu key and you can go into a whole bunch of options including cc
May 25, 2009 | RCA Universal Remote Control
RCA Universal Remote Control #451--Closed Captioning Will Not Turn Off
I can't figure out how to turn the cc off either. I went to menu and then audio then captions and off but they still won't go off. The captions are only on when I am watching HD channels. Anyone know why?
Oct 11, 2008 | RCA Universal Remote Control
Good picture good sound use antenna
This is a simple problem, somehow ypu have the closed caption on, either from the remote hit the CC or closed caption button till it says off or find the closed caption in the menu and turn it off
Mar 10, 2008 | Quasar VV2007 20 in. Combo
Rca system link 8av remote How do I turn off closed caption??
CC is usually turned off by selecting an inactive choice,i.e.
If CC1 is on, then try CC2......
Further info ? Please provide Model # of TV.......................T.
Dec 31, 2007 | RCA Universal Remote Control
RCA RCU4GLW Remote Control Logo
889 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
