Question about Kohler K-5988-2-7 Entree Self-Rimming Kitchen Sink, Black Black
Kohler 5988 Sink leaks from soap dispenser spout (?) when dishwasher is running
Our Kohler 5988 sink discharges water from what I think is the soap dispenser connection all over the counter/backsplash when our dishwasher is in a drain cycle. I inspected under the sink and find what looks like a strange connection - there are two hoses coming from the soap dispenser hole (if this is what that actually is), one leading to the dishwasher and one to the disposal. We are renting and did not install this sink, so we don't know if something has been modified or even how this feature is supposed to work. We have to "supervise" when we run the dishwasher or else water ends up everywhere. Can you help?
  • Paul's Plumbing
    Paul's Plumbing May 11, 2010
    Is it a kitchen sink? Do you have a garbage disposal and a dishwasher? If so, it is the vacuum breaker for the dishwasher drain line and it is clogged between the vacuum breaker and the disposal. I will help you fix it if this is the problem.
  • 101 Answers
Hi.. Its a breather or "vent "and its clogged. Remove the drain tube under the sink that runs from the vent to the connection on the drain( under sink). Clean vent and replace. Please send me some Positive feedback if I've help. Thankyou!
Posted on Jan 24, 2009
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
How to maintain cleaning and scratch free black sink,my sink has spots and scratches on it. how to avoid these problem
Using soft scrub or some brand similar is the best thing to use. Manufacturers reccomend only soap and water, but soft scrub is best. Be sure to never use abrasives on any fixture, it will scratch and void warranty
Kohler makes a cleaning agent for cast iron sinks, if this is what you have.
hope this helps
Apr 14, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
The spout on built-in chrome sink soap dispenser fell out
The only good solution here is to purchase a new pump.. Sorry
Kurt
Mar 21, 2009 | Home
KOLHER Soap dispenser won't dispence soap.
Pull the dispenser out. Put it in semi hot water foe a few minutes to clean it. Then put the pickup tube in a glass of water and pump it untill water comes out. They get clogged with soap after so long.
Good Luck
Kurt
Mar 01, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Breather for the dish washer
Yes the breather can be placed under the sink. Just be sure to mount it above the level of the dishwasher. You can either screw it to something wood or use tie straps to tie it up to a screw.
Dishwasher leaks at top of sink
hi some old dishwasherhas that y ,,,,,,the y is there so when washer drains it does not go bact to the machine,,,,,,,,some times the pipe that goes from y to disposer gets clugged and you can turn the hole tourd the sink the drain into sink
Jan 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Kohler K-5988-2-7 Entree Self-Rimming Kitchen Sink, Black Black Logo
532 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
