Question about Pondmaster Large Foam Pre-Filter 250gph-3600 gph
Pondmaster mk11 3600 not pumping - Pondmaster Large Foam Pre-Filter 250gph-3600 gph
Why is it not pumping?
Pondmaster pump repair part 1 - YouTube
? 3:12
www.youtube.com/watch?v=KFbe0xmk2tk
Oct 29, 2011 - Uploaded by Asianleful Pondmaster pump repair part 1 ... How to build a simple PVC Hand Pump - the Peters Pump - Duration: 20 ...
Aug 07, 2015 | Pondmaster Garden
I just bought the Pondmaster 260 pump from Overstock. There are NO instructions in the kit. Do you have a manual I could download on line? Thank you. Ellen Goodell
The manual is located on the Pondmaster site in PDF format: http://www.pondmaster.com/instructionsheets/ZG098.PDF
If you need the program to view it the reader is free at: http://www.adobe.com/products/acrobat.html
May 12, 2011 | Pondmaster PM 250 gph Mag Pump Pump 250...
Do you submerge this pump?
Yes, at least enough for 2 inches over the pump.
Apr 03, 2011 | Pondmaster 140 GPH Magnetic Drive Utility...
Pondmaster 1200gph pump stopped working. Inside
Sounds like the impeller broke.
Just remove the 4 phillips head screws to remove the housing, then pull the impeller out. When replacing the impeller be sure to have a good grip on it as the magnetic attraction will pull it in pretty hard.
The pump may still be under warranty, if so call the number on this web page: You can also order parts from them.
http://www.dannermfg.com/contact.asp
Jul 08, 2010 | Pondmaster PM 1200gph Mag Pump Plastic...
My Pondmaster Mag 3600gph pump quit working too
welcome to pond life they rarely last more than 1 to 2 years
Jun 27, 2009 | Danner Pond Pondmaster 500 Gph Mag - Drive...
Shaft fell out of Pondmaster 700 Gph pump.
DANNER MANUFACTURING, INC. 160 Oval Drive Islandia, N.Y. 11749-1489 Phone: (631) 234-5261 Fax: (631) 234-4778 e-mail: Sales@dannermfg.com
May 06, 2009 | Danner Pond Pondmaster 700 Gph Mag - Drive...
Pondmaster 250: Impeller or motor broke?
pondmaster 250 comes with a 3 year manufacturer warranty you should just exchange it for a new one. Overheating from low water sounds like the issue but as long as the shaft and housing are not scarred from debris they will replace without any questions
Nov 29, 2008 | Danner Pond Pondmaster 250 Gph Mag - Drive...
Is power to the pump insides; if the best thing is to re place it; I couldn't repair my same pump.
Oct 31, 2008 | Danner Pond Pondmaster 500 Gph Mag - Drive...
Pondmaster Large Foam Pre-Filter 250gph-3600 gph Logo
42 people viewed this question
Top Pondmaster Garden Experts
Dennis Key
Dennis Key
john h
Are you a Pondmaster Garden Expert? Answer questions, earn points and help others
