Question about Samsung DVD-V3500 DVD Player/VCR
I can not play any disc on my player
The on screan message is- The disc can not be played please check disc.have cleaned the lens via cotton bud and alcohol
I have also used bib dvd lens cleaner
Therefore I suspect the lens itself may not be the problem
can you help please
thankyou Gary L
  • 4 more comments
  • teddy_squidg Jan 21, 2009
    My player will not play any discs either copied or shop bought. It would not even allow the bib cleaning disc to remain in the player to do its job it kicked that out aswell
    how do I update the software ? and yes I think it is out
    I have tried to find region setting on the on screen menue but I cant find it.
    thankyou for your suggestions but this is sounding beyond my limited abilities,do you feel as I do that I need someone else eyes to luck at this problem
    No problem with eject button
    how do I change the ntsc/pal manualy on my player
    Scholar:
  • 108 Answers
MrScary66613 and ginko are correct.
teddy_squidg,
Replace the part they are telling you about if it is within your capabilities or purchase a new player. You can also opt to have a tech replace the part,but it may cost more than a new player.
Have a great day and good luck.
Posted on Jan 21, 2009
    Sergeant:
  • 367 Answers
There are no firmware updates for this model samsung. Check here for Proof
The lens may be out of alignment as well.
  • Rob Houg
    Rob Houg Jan 21, 2009
    This issue has nothing to do with region settings or NTSC or PAL. If you have the dvd player on either NTSC or Pal the dvd will still play it will just be jumbled on the screen it is not the playing format it is the signal that is produced. This dvd player is saying cannot play disc.
    This unit need a service tech unless you feel comfortable opening the device. and hoping for the best .
    My reccomendation see how much it will cost at service shop if too much then replace the unit.
    sorry
  • Rob Houg
    Ginko has a valid point as well
    Genius:
  • 2,920 Answers
If its not reading the disk after you cleaned the lens then it may be time for a new player...if you take it to a shop it will cost more than a new player to fix so your best bet is to spend that money and buy a new one
    Brigadier General:
  • 3,614 Answers
You must need to set the ntsc/pal options manually on your player.
Try to adjust and set this setting. And try to use ridata or tdk media or other compatible media which your model can play.
Hope this initial info, helps.
  • micromaster
    micromaster Jan 21, 2009
    Option in one of it's Set Up
    Menus to Change the Output to PAL , NTSC or Auto, try
    Changing it and see if that Makes any Difference.
    Auto is
    Usually the Best Option as the Player then Outputs the Correct Setting.
  • micromaster
    eventually as mentioned earlier this can be only on the REGION SETTING for the player.
    if no such changes has made on this settings. check and see if the procedure provided will solved the issues.
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    To convert this player to Multi-Region playback
    • First you may need to establish a password/access level in
      the parental lock section of the
      player's set up menu
      1.
    • Press the TV View button on your remote
      control until the Samsung DVD logo appears on the on-screen
      display
    • Press the Repeat button on your remote
      control
    Just repeat the whole process if the
    procedure has not made successful, and use the
    Subtitle button on your remote control instead of Repeat.
    Using the remote control
    enter the code below;
    You must first know what Region that is currently
    set on your
    player
    For the list of
    appropriates Regions code, see here;
    • for Region 1 use 2, 9, 3,
      3 and 4
    • for Region 2 use 3, 8, 7,
      6 and 7
    • for Region 3 use 5, 6, 7,
      3 and 2
    • for Region 4 use 7, 6, 8,
      8 and 4
    • for Region 5 use 5, 3, 8,
      1 and 4
    • for Region 6 use 2, 4, 4,
      6 and 2
    **The CODE should
    be displayed on the screen. This will also indicate the current Region setting stored on your player.
    • Press the 9 button on your remote control for Region free or Press 1
      for Region 1, 2
      for Region 2 and so on.
    • Press the Open button on your player
    • Now Power the
      unit off, then power the unit on again.
    hope the provided solution helps.
    Sergeant:
    Champion:
  • 435 Answers
Check if the eject button is fine.
It may cause the player to always eject disks inserted not letting to play ...
    Genius:
  • 1,550 Answers
The problem is due to
  • Bad component in optical pickup.
  • Microcontroller problems.
  • Defective ribbon cable to optical pickup.
    President:
  • 1,990 Answers
Welcome to Fixya! It is the Lens causing this Problem. The lens deyermines whether or not that it can read what is in the Player and if it is Faulty it will kick out every time.
  • Travis Humphries
    Travis Humphries Jan 21, 2009
    Call 1-866-925-PART (7278) To locate the Parts for the Repair. You cannot update the Software on this Player. Just replace the Lens.
    Master:
  • 416 Answers
Please check the region setting at DVD and disks you playing
You might accidentally change the region mark at DVD
Go to menu - settings - DVD region settings
If wont help lens is damaged
Good Luck
  • Samsung Master
  • 19,396 Answers
If the unit is fully working an unit cannot read disks , even if motor is spinning, then the lens it is always the problem.
If you already cleaned the lens, then there is need to check the contacts to lens pickup, and the lens pickup must be replaced.
An easier operation is replacing the whole DVD drive, that usually is a stand alone unit inside your player.
  • Ginko
    Ginko Jan 21, 2009
    If the unit does not read any DVD or CD, then it is rather unlikely , that this happens because of an outdated firmware.
    Regarding regional settings, when it is regional settings you get the wrong region message displayed.
    Check if the disks are spinning, if they are not , replace the belt, if they are spinning , then replace the lens pickup.
    Call toll-free at
    to get replacement parts price.
  • Samsung Master
  • 13,433 Answers
Have you tried updateing the internal software in the dvd player? it might solve the problem.
But the issue is most likely the drive itself, probably bad lens or faulty drive. The firmware update indeed might help but I suspect the drive is the issue. Hows warranty? out?
  • Ekse Jan 21, 2009
    there is no firmware available from samsung at this time. Replace or service the drive.
    Brigadier General:
  • 5,158 Answers
Are these disks you have burned yourself or store bought... could be regional or copyright issues you are having.
Robert
It continually says no disc and wont play
What to do:
buy a cd lens cleaner then play the cd lens cleaner until you hear a sound with the instruction then just follow the instruction until the cleaning process end after that play your dvd movies again
if still not working go to the nearest service center or if you know how to open the cover of your player to manually clean the lens by a cotton buds inside, but be careful the lens is sensitive. tips on cleaning do not put any liquid to the cotton buds just do the dry cleaning
thanks for using Fixya
Jun 01, 2011 | Televison & Video
My dvdv 6600 dvd player cannot played anymore
If Your player used to play disc before but all of a sudden stopped playing disc, yet it powers on and try to read a disc and come up with a 'no disc' error message or loads and does not come up with any message, then it means there is a problem with the laser/lens of the player. If it does not power on at all, then it means the problem is from the power board which is inside the player.
For the no disc error message, the solution is for You to clean or replace the lens of the player.
To clean the lens, Please get a laser/lens cleaner disc and insert it into the player, that will clean it for You, but if You want to clean it manually, please follow the steps below: You will be needing a cotton bud,a cup, a screwdriver, and a glove.
  1. Turn off the player,
  2. Unplug it from the power source and wear Your glove,
  3. Unscrew the player and keep the screws in the cup in order for it not to be missing,
  4. Then You slide the cover open,
  5. Unscrew the plastic cover that holds the disc in place for the lens/laser to read it,
  6. You will have direct access to the laser/lens,
  7. Use the cotton bud to carefully clean the laser/lens which is the crystal like object held in some casing,
  8. Screw back the disc support plastic that holds the disc,
  9. Then You test it with a DVD before screwing it back together.
If that does not solve the problem, then it means You have to replace the lens, to do that, please follow the steps above to step 6, then follow the rest of the instruction below:
  1. Disconnect the flexi ribbon that connects the lens to the main board,
  2. Carefully remove the laser from where it is connected to,
  3. Replace it with a new one,
  4. Reverse the process to reassemble the player back together,
  5. Then You plug it to a power supply and test it with a disc.
Hope this helped. Thank You for using FixYa!!!
Jan 28, 2011 | Samsung DVDV 6600 DVD Player / VCR Combo
Won't play dvd
If your player wont play dvd, then it means there is a problem somewhere inside the unit. Most likely the lens is weak or dirty. First try to use a lens cleaner for the player to see if it will play any disc, if it does play the dvd, then it means the lens was just dirty and needed to be cleaned.
You can also try to clean your lens, by taking the player apart and using a cotton bud to clean it up. To take the player apart, you need to get a star screwdriver, then you unplug the player, then you unscrew the screws around it, slide off the back cover, then you unscrew the hook that is above the lens that covers holds the disc in place, then you use a cotton bud to carefully clean the lens. Before you reassemble the player just screw the disc holder that is above the lens back and plug it, then try to play a disc, if it does not play a disc still, then it means the lens is weak and need to be replaced.
To replace the lens, just take out the disc tray, disconnect the flexi ribbon that connects the lens to the main board, then you disconnect the lens itself, and replace it with a new one. then you reassemble the player back together.
This time, it will play your dvd discs.
Hope this helped. Take care and good luck
Jan 07, 2011 | Philips DVD963SA DVD Player
I get a no disc error and so far blowing air in it has not helped
It sounds optical laser lens is dirty and need cleaning.
Put lens cleaning disc in player and press play, disc will spin and might clean lens to solve the issue.
If that does not fix the problem, unplug player from wall socket, take off top cover and clean lens with good quality cotton bud gently and then check does it play disc. If problem still exist then optical lens got defective and need to be replaced. Local tv repair shop will replace it but replacement would cost you much.
Hope these info will help you.
Thanks.
Jun 09, 2010 | Philips DVP642 DVD Player
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Our only one month old portable insignia dvd player will not read any dvd...get message stating "loading" or no disc...Please advise
try clean the lens with cotton buds gently/smoothly...try audio cd or vcd to play if it will play and not playing if the disc is dvd...lens for replacement partially burnt
Jan 03, 2010 | Insignia I-PD720 Portable DVD Player
I have a sony dvd player (dvp-N5725p) and it says cannot play disc now. I hear it trying to spend but nothing no play or anything it spins until it states cannot play disc now.
Try to clean optical lens of dvd player with soft and nice quality cotton bud / swab by opening top cover of player.
There might be chance of lens sled mechanism stuck so move lens left-right for 2-3 times.
If cleaning doesn't work, you need to replaced optical lens.
Oct 23, 2008 | Televison & Video
Loading Error then reads NO DISC
the disc cleaner is not exactly clean your lens! much better to open your DVD and you clean the lens with 100% cotton or cotton buds then slightly touch your cotton to lens in clockwise to remove the dirt!
Sep 20, 2007 | Concept DVD-168C Car Video Player
The Machine only plays when it wants to
TRY CLEANING THE LENS WITH A CD CLEANER OR do it manully with a bit of Vodka and a cotton bud carefully clean the lens in a circle motion then carefully dry the lens with the other end of the cotton bud put it all back together and see if that works
Jun 10, 2007 | Sony CDP-C305 5-Disc CD Changer
Samsung DVD-V3500 DVD Player/VCR Logo
23 people viewed this question
Henry  Thomas
Henry Thomas
