Question about Tensor Home
How do you change the lamp on a Tensor FS124?
The lamp is a 13WPL-S CFL bulb. Hard to access. Does cover come off?
2 Suggested Answers
  • 5089 Answers
SOURCE: Do I need a bulb with this same wattage,?
18 watt should work fine, but give less light.
Posted on Jun 27, 2012
My led lights start to strobe when I turn on exterior light that is fed from the same line circuit. Solution?
There are two things coming into play here; the lamps and the dimmer(s).
First; LED and CFL type lamps that are to be used on a dimmer switch - must be identified for that use. Looks for the word dimmable on the packaging or bulb itself. These lamps are generally a little more expensive than their non-dimmable counterparts. If it does not indicate it is dimmable, then it isn't - and should not be installed on a circuit controlled by a dimmer switch.
Second; a dimmer switch that will be used to control LED and CFL bulbs (that are identified for use with a dimmer) must also be identified for use with dimmable LED and CFL bulbs. Again, these dimmer switches will be identified for this use and will cost more than those that work with standard filament type bulbs.
Lutron has dimmers for your circuit called a "C•L™ Dimmer" and supports Incandescent / Halogen, Dimmable Compact Fluorescent (CFL) and Dimmable Light Emitting Diodes (LED) type lamps. have a look here:
Lutron Maestro Dimmer and Switch Models
Also, be wary of the total load (wattage) of the lamps being controlled. If you have multiple dimmers in the same box, derating of the switch's wattage capacity (due to increased heat) will be required.
Dec 03, 2015 | Maestro Electrical Supplies
Can I use a 23W CFL bulb in place of a 13W, if the desk lamp says to use a 60W max bulb?
OF COURSE less than 60 watts is it not . and they are a lot cooler
May 08, 2015 | Dryers
WHERE CAN I GET A MANUAL FOR A TENSORVISION MAX FSF402BR FLOOR LAMP WITH NATURAL LIGHT FOR MY LOW VISION. IT HAS NOTHING TO DO WITH A TELEVISION! IT IS A LAMP MADE BY TENSOR CALLED VISION MAX # IS...
I wasn't able to find their web site. The suspected website is for sale and I found that the inventor has died. It may be that it is no longer being made under that name.
This is a link for ordering replacement bulbs.
Tensor Corporation BULB ORDER FORM Free Online Doc
Oct 15, 2014 | Televison & Video
Compact Flourescents won't work in ceiling fan
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
Dec 17, 2013 | Hunter 52" Ceiling Fan With Light And...
Dec 14, 2011 | Tensor Home
How to check high power amps by using bulb series technic
You can use CFL (Compact Flourescent Lamps)
100W CFL is cooler and brighter than the standard 100w bulb. Therefore, for the same performance, a 60W CFL is equivalent to the
100W bulb.
Sep 22, 2009 | Audio Players & Recorders
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
Signal light bulb change/who and where
  1. From under front wheelhouse, remove access cover behind park and turn signal lamp
  2. Through access hole in wheelhouse, rotate park and turn signal socket counterclockwise one quarter turn.
    1. Pull socket from back of lamp.
    2. Pull bulb from socket. INSTALLATION
      1. Align key on bulb base to groove in socket and insert bulb into socket.
      2. Through access hole in wheelhouse, insert socket into back of lamp.
      3. Rotate park and turn signal socket clockwise one quarter turn.
      4. Install access cover and verify lamp operation.
Hope this helps with your prob
Mar 27, 2009 | 1998 Plymouth Voyager
Home Logo
101 people viewed this question
Top Tensor Home Experts
Donni Steen
Tom Chichester
Are you a Tensor Home Expert? Answer questions, earn points and help others
