You need to remove the lower toe kick plate, then remove the guard plate behind that (will tak a t-20 or t-15 torx bit to do this) and drain the water that has most likely collected under there caused by the sink backing up. You can use a wet vac or just soak it up with a towel. If there is no water down there, and you do not hear the drain pump run for a few seconds when you start a cycle, teh you need a drain pump. It is located on the left behind the plate you just removed, and just twists out. look at the new one to see where the locking tab is. Good Luck!
dishwasher filled with water from sink drain F2 comes on when starting it drained the dishwasher but stays on F2
