Question about Toshiba Satellite P35-S609: Pentium 4-3.2 GHZ, 512MB RAM, 80GB Hard Drive, DVD-RW/CD-RW, 56K Modem, Network ... (SATELLITEP35S609PENTIUM) PC Notebook
My laptop after starting goes to the window xp intro screen then restarts again and again. it wont even recognize the boot disc that came with it
    Sergeant:
  • 367 Answers
Take cd rom out of computer by pushing the release. Reset the drive back into pc. Let me know if this helps .
Posted on Jan 21, 2009
  • 28 Answers
All right, first you gotta check your BIOS settings goto to bbot tab and check the order of your drives at the top must be the CD-rom drive, then check that "boot to optical devices" and "boot to removable devices" are enabled then restart your computer with  a bootable cd and goto repair mode, and perform check disk to the drive in your windows is installed. The command is "chkdisk C: /F /R" hope that helps, please rate the answer
I am stuck in Safe mode with command prompt on my Dell 620 laptop windows xp every time I type a command it says it is not recognized as an internal or external command, operable program, or batch file....
try restarting the laptop and before anything pops up on the screen hit the f8 key and the boot menu comes up then start in last configuration that worked and see if it helps
Sep 30, 2013 | Dell LATITUDE Computers & Internet
My drivers got renamed some how and then they crashed i have it so it will boot up now but windows xp is gone try to reinstall wit windows xp install disc and its stuck on a screen saying can not complete...
Thanks for using FixYa.
The Windows XP setup is detecting that you have a current installation of Windows XP. What you need is to do a clean install. You can find information on how to clean install Windows XP here:
http://michaelstevenstech.com/cleanxpinstall.html
Make sure that you back up all your data before doing a clean install as this will delete all data on your machine.
I hope this helps. Thanks and good day.
- HotRatchet
Feb 14, 2010 | Office Equipment & Supplies
My computer will not recognize my Windows XP. When I turn it on the black screen comes up giving me the option to start in safe mode, go to last start up when it worked properly, start in safe mode with...
Select boot from CD option in BIOS level and try to boot from OS CD and reinstall the OS will solve your problem.
Revert back for more clarifications or assistance required.
Dec 13, 2009 | AbleSoft Teacher's Toolbox 4.0...
I have a dv100 laptop when you turn it on it goes to the windows xp loading stays there then shuts of and restarts the same way I cant get it to turn on. I can occasionaly get the safe mode screen it still...
Try to Repair XP
  1. Insert Windows XP disc to CDROM
  2. Select Boot from CD--option
  3. Select "R" for Repair---it will enter to Recovery Console
  4. run Command---chkdsk /r
  5. after completion--reboot system and check
Oct 01, 2009 | HP Pavilion dv1000 Notebook
Boot failure self HDD test #1-7 XP PRO.
Hi this Alex You can use Ntfs for dos programm which allow you to access ntfs partions on while dos loaded. then you will be able to get you data copied
Sep 23, 2009 | HP Pavilion dv4000 Notebook
Computer wont start up fully
Your boot menu for Windows is corrupt. Try to boot from the windows installation disc and make sure to key any key when told to boot off the disc. Once the windows files load, you will have a choice of what to do next. If you have XP, choose the repair option and you will be faced with a black DOS screen...after the blinking cursor type
FIXBOOT hit enter
Try to boot the computer without the disc in it. If it does not boot, then boot off disc again and this time type:
FIXMBR hit yes and enter
Try once again to boot without the disc.
Also try to boot into safe mode by tapping F8 when you see the Compaq name come up during starting. If you can get to the multiple boot up option screen, scroll to "Safe mode with networking" and choose that. If it boots then you can go to the start button > accessories > system tools > system restore > choose a restore point back a day or two and follow the prompts.
If you have Vista, boot off the disc and choose start up repair. If that doesn't work, boot again and choose restore computer to an earlier time. Again choose a restore point back a few days. Good luck ParrotHead PC Repair
Sep 06, 2009 | Compaq Evo N610C Notebook
Brand new notebook .. windows then, screen freeze..acer picture
This may require a "repair" of windows.
Get a Windows XP Operating system disk with the correct service pack that the notebook has installed (usually XP SP2).
1. Boot from it (put it in CD drive and restart the laptop).
2. If you still get the same problem start up, you need to set the laptop to boot from CD.
3. Restart laptop, press Delete key or F2, or F12 (it should say one of these on the screen) to enter the Setup. or another key to get "boot options"
4. In Setup (BIOS) Use Right Arrow to find the Boot Options. Use the instructions to move the CD-ROM to first position, above HDD (hard drive). Press Esc, then F10 to save your changes and exit.
5. The XP CD Rom should now run. It should come to a screen where you are asked to press R to repair windows.
6. When it comes to the command prompt, restart the laptop
Hopefully the laptop should boot OK again.
Jan 25, 2009 | Acer Aspire One PC Notebook
HP Pavilion ze5500 - Laptop won't recognize hard drive.
Hi. Once I had this similar problem with a HP Pavilion dv9000. "No Operating System"; "Windows Recovery Console cannot continue because there's no HD present..press F3 to Exit". No progress with Safe Mode nor Command Prompt, etc.
Then I went to the Bios, change tab to "System Configuration" and change the "Sata Native Support" to disable, whitch says that by changing to disable the HD would work better if the Operating System are Win2000 and Win9x.
Hit "Safe and Exit" and the computer started normaly!
I relly don't know how or why. It just work.
I don't know if would work for Linux (mine had Windows XP) and don't know the Bios view of your laptop. But you can explore and give it a try.
Hope this helps.
God Bless You!
Jan 06, 2009 | Computers & Internet
Laptop restarting
Although it could be the hard drive, it could be any number of things as well. First, when the computer starts up, press the F8 key to bring up some options. Select disable automatic restart. This should allow the computer to stop at a blue screen so we can get some information from it. Do this and report back what that information says and we'll go from there. Thanks.
Jun 14, 2008 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Restarts before windows loads up.
hey hey chill...simple my friend just have your windows service pack with you inhand.Turn your Laptop on immidiately when your CD-ROM/DVD-ROM starts flashing its light, open it then insert your service pack disc (its the CD/DVD you receive when purchacing the laptop) then let it restart again...then again when it starts press F8 repeatedly until you enter a some menu then re-install the Windows Xp again from the disc and walla your Pc will be fresh again...
Feb 24, 2008 | Fujitsu Siemens Lifebook T4010 Tablet PC
Computers & Internet Logo
158 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
