Question about Acer 91.AB370.001 Network Adapter
LAN not conecting
I have a LAN card of tech-com ,i use XP
i installed it and it instaled properly wen i conected it to my cable modem ,it shows "" aquiring network adress"" .after some time it says cannot be conected ,i tried repairing but no use i tried reinstalling but no use
wen i conect same conection to my inbuild LAN it gets coneced wat could be the problem
  • 85 Answers
Remove ur lan card and clean it and install it
Posted on Jan 30, 2009
Why Thinkpad T23 2647 4MP can't conect net after installed windows XP?
I do not use an automatic driver detection program, because they have a tendency to install the wrong drivers.
I look in Device Manager, and use the driver that matches THAT device, the O/S used, and is the newest version, (Date), with all the bugs worked out from an older version.
For your laptop that would be;
Ethernet Driver for Intel PRO/100 VE LAN that is the 49675 version, and has the date of November 8, 2002,
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS002672
Regards,
joecoolvette
Jan 28, 2012 | IBM ThinkPad T23 2647 Notebook
When installing the disk it says the ethernet cable is not conected when it is
Connect the LAN cable from the D-Link to the LAN port on your computer. If you have alreadt done this and you get this error message then it is possible the LAN card driver has not been installed.
I suggest you install or reinstall the LAN card driver before running the D-Link installation disk.
Jun 20, 2011 | D-Link DIR-600 Router
Cant get online wireless'ly
The procedure is 1st. to connect the LAN cable to the router (not to the LAN port marked WAN) and use the browser to configure the Belkin router for the wireless settings.
In the wireless setup change the SSID from the default SSID to what you like., set up encryption (if your wireless card supports WAP then use WAP encryption, if not use WEP 128bit)
Also change the administrator password (write it down and put it in a safe place).
you can disconnect the LAN cable from the computer and router.
If you had not installed the wireless driver for you wireless card, do so now.
Connect the LAN cable to the WAN port on the router and the other end to the Hughesnet.
Now configure the wireless card with the SSID and the encryption that was set on the router.
If all goes well you should see your router and get on to the Internet.
Get back to me with error messages if you have problems.
May 22, 2009 | Dell Inspiron 4150 Notebook
How to connect usb conection from my data one "UT-300R2U" modem to compaq laptop.we have usb cable and driver cd but drivers are not installed in my laptop.plz give me the complete solution for this...
If you are using Windows Xp, just connect the modem using USB/LAN it will be automatically detected & software for it will be installed. Then you can just set up a connection, put in your username & password, done.
If you are using Windows Vista / Windows 7, modem in LAN mode will be installed automatically like XP, but not in USB mode. Because there's no USB driver for UT300R2U (BSNL modem) in Vista. You need to find a ZTE Remote NDIS device driver, install it & then you can connect. Hope this will fix your problem.
May 12, 2009 | Computers & Internet
No LAN conection displayed in network connections
check that proper driver is installed, in the device manager that shows excmlatory mark that indicates proper driver not been installed, update the driver it will works
Mar 22, 2009 | HP Pavilion a6547c Refurbished AMD Desktop...
When modem is conected through router computer not recognizing internet connection. with or without modem bridged
Go to Control Panel -> Network connections make sure the Local Area connection is enable. if this working fine then replace you LAN card. LAN card is connected to the PCI slot of the motherboard. And install drivers for your LAN card. Thank you
Sep 06, 2008 | Computers & Internet
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
Network cable unplugged
Since it only happens when it rains, it sounds like you may have damaged cable between the modem and the drop. You will need to physically inspect whatever cables you have access to, and you may need to call a field tech out to repair the damaged cable.
Nov 05, 2007 | Arris SURFboard SB4220 Modem
Modem conection
In order to troubleshoot this problem, I need the following information:
Are you using a router?
What OS do you have?
Does your modem have a steady "online" light?
What IP address is coming up in ipconfig?
Oct 03, 2007 | Computers & Internet
Belkin mimo installation
what you should have purchased was a modem/router and not a seperate router to connect to your modem, but the modem should connect to the cable/adsl port (wan) using the initial RJ45 lan cable, and then a lan cable from one of the 4 ports on the rear to each pc.
Sep 24, 2007 | Belkin (F5D5231V4-SN-PD) Router...
Acer 91.AB370.001 Network Adapter Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
