Question about Reddy Heater-30-55,000 BTU Variable
Reddy Heater RM60 HSI Forced Air Heater: Pump Pressure Issue!!
I have had issues with this unit over the past month or so. Firing-up, running for any length of time, etc. Have even had to a dealer twice to be repaired.Would work for a while then not. Replaced the following: Ignitor, fuel filter, photo cell, pump filters, nozzle, nozzle adapter, air/fuel lines and rotor kit. Purchased a pressure gauge to check, (specs call for 3.4psi), put all back together, pressure indicated 2.0 or so; obviously, would not fire. Relief screw adjustment made NO difference to increase pressure per gauge. I just ordered a new end cap and pump adjustment kit as now the treads are stripped from the adjustments (or lack thereof) ANY OTHER SUGGESTIONS WOULD BE HELPFUL AT THIS POINT.
Thanks! reddy heater RM60 It just shuts off after running a minimum lenghth of time
Any Suggestions???
  • austinmh1 Jan 27, 2009
    Yes, I am very interested in knowing how I can fix this nasty POS. I am having the exact same problem...
    Problem Solver:
  • 6 Answers
Take the pump vanes out and clean them with 400 grit w/d sand paper, lay on flat surface and go in a 8 pattern,
Posted on Dec 19, 2012
    Problem Solver:
  • 12 Answers
This is a pulsate heater. using a non liquid gauge you should see a fast sweeping needle on your gauge between 3-4 no lower no higher. if no sweeping check pulsate valve in the filter tube orange
rubber like in the filter tube wash out and make sure all hosing is air tight
Posted on Jan 30, 2009
    Problem Solver:
  • 3 Answers
Ground wire on the circuit board needs to be checked and these units need to have a GOOD three wire cord with a proper grounded outlet
Posted on Jan 21, 2009
New photocell but no fix.
Troubleshooting a Reddy Heater, HSI type
www.reddyparts.com/hsi_tips.htm
The photocell starts looking for a flame in the chamber; When the atomized fuel ...Water in the fuel - people love to buy parts... but this is a free fix, just drain the tank.... Not so with the new heaters- you adjust to suit the computer, not you.
Troubleshooting a Reddy Heater, spark plug type
reddyparts.com/sp_tips.htm
Troubleshooting tips for Spark Plug type heaters. ... In a perfect operational Spark Plug type heater: ... The photocell starts looking for a flame in the chamber. ... then take the heater to someone else to fix, because you will never make a heater ... on aheater,--- but if the air pump pressure is not correct....the heater will not run!
[PDF]Owner's Manual and Instructions - LB White
www.lbwhite.com/files/5913/1672/2821/125k-210k.pdf
Your new L.B. White heater incorporates the benefits from the most experienced ...Owner's Manuals and replacement labels are available at no charge.
[PDF]Forced Air - yourheater.com
www.yourheater.com/pdf/Forced%20Air%20E.pdf
Jan 03, 2016 | Heating & Cooling
Reddy-Heater will start then run about 10 seconds then stop.
The heater has a photocell that has to see the correct flame or it will cause the heater to turn the unit off.
I would suggest checking the the pump pressure and the output filter to make sure you are getting the correct amount of pump pressure to the nozzle.
Here is a link to the actual service manual.
http://www.desaparts.com/hsi.html
Oct 08, 2012 | Reddy HEATER RH170T 165,000-BTU PORTABLE...
R100 reddy heater, low pressure forced air heater. the heater ignites, motor runs for 30 seconds then shuts down. photo cell good, filters clean, no ignition board, pump pressure unknown.
The R100 is a kerosene heater and the RLP100 is a propane heater so I am not sure when one you have.
If it is kerosene then you may need to check the pump pressure. Also the Safety swith can give you a cut out after 30 seconds.
If the unit is Propane then you could have a bad control board or a flame sensor.
You can call our service department at 1-800-475-5660
Thanks
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
Heater will not stay on rm60 reddy heater
When you say the heater is coming on does it actually ignite or is the motor just running until the safety circuit kicks it off? The air pump on you heater should blow at 3.5 to 4 psi which runs up to the nozzle which is a venturi which sucks the fuel out of the tank. The motor will generally run for 20 to 30 seconds trying to ignite. If the flame sensor does not sufficient flame during the time it shuts the motor off. Check these items and let me know what you find.
Jan 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
Reddy heater blows cold air
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 30, 2008 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy Heater-30-55,000 BTU Variable Logo
524 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
