Question about Verizon Communications Samsung Gleam Cell Phone - Black
Sounds off Activated
All sounds off is activated on my phone & I cannot find a way to remedy this. Nothing appears in the booklet accompanying the phone. Any suggestions?
  • xysma333 Jan 21, 2009
    On the left side of the phone should
    be a button that increases/decreases the overall volume. Press &
    hold until the level indicator increases to the maximum. Accidently
    pressed this button will affect all volumes on said phone.
  • achiesa7 May 09, 2009
    all other sounds are on except my ringer. seem like it is on silent mode.
Its a volume setting. Just hit volume up and this will resolve the issue. I had the same problem with my phone.
Posted on Jul 31, 2009
Our washer started vibrating violently, and now will not spin. The washer appears to drain fine, and then it sounds like it is trying to spin, but nothing is spinning.
when the tub gets out of balance there is a switch that is activated to stop the machine and pause the program
that switch is normally the lid switch which is activated by a lever attached to the side of the outside tub
check that the elver is not on the wrong side of the switch but is free of in when stopped
Oct 19, 2015 | Washing Machines
What is Technical Fault 51? It appeared a few moments ago on our machine, but when I switched it off and reset the machine it worked as normal again.
F51 Heater pressure switch The program is interrupted and the drain pump is operated. The display shows Technical fault F51. Call Service Department. The buzzer is activated for 2 minutes.
Background information:
Start position: One second after the program start, heater relay K1/1 is activated. This enables a check as to whether the contacts on heater pressure switch B1/13 have closed on switching steps 21/22 or 11/12.
Cause:
Heater relay defective; contact open.
Remedy:
Replace the heater relay.
Cause:
Heater relay solenoid defective.
Remedy:
Cause:
Connection from heater relay to electronic module open-circuited.
Remedy:
1. Check plug connections.
2. Check the connection wires for continuity.
Cause:
Heater pressure switch open- or short-circuited.
Remedy:
Replace the heater pressure switch.
Cause:
Connection from heater pressure switch to electronic open-circuited.
Remedy:
Cause:
Foreign objects in heater pressure switch.
Remedy:
Apr 14, 2015 | Miele Washing Machines
How do I fix problem F3 and spray arm faulty on my KO FAVORIT 8080
F3 - The anti-flood protection system has activated.
When in operation the fault message F3 appears in multi dispay:
  • First close the water tap.
  • Pull out the power plug.
  • In the case of hard-wiring: turn off the electricity supply, remove the fuse and disconnect.
  • Check float microswitch and float of styrofoam.
  • Find and remedy water lakeage in the bottom of dishwasher.
Dado
Jan 22, 2015 | AEG Dishwashers
Have just bought a secondhand Miele G7859 dishwasher. When turning on to any programme, it shows F11 fault code and beeps. I'll happily work through any suggestions! Thanks in advance Andy
F11 - Drainage fault
This code means that water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning.
Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause:
Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause:
Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause:
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause:
Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
In other cases, owners found a piece of wood inside the door latch mechanism and removed it. The F11 error has not appeared since.
Hope ths helps.
May 20, 2011 | Dishwashers
Dishwasher miele g2582scvi fault code f25
Check this out.
F25 Desired temperature fault At the end of the wash program, the display shows the message Technical fault code F25 - Call Service Dept. The Status LED flashes. The buzzer is activated for 2 minutes. During the heating stage, the desired temperature has not been reached within the given time (minimum 75 minutes). In subsequent wash blocks, after this fault has registered, the heating is not activated and no rinse aid is dispensed.
Cause:
Heater defective.
Remedy:
Replace the heater.
Cause:
Remedy:
1. Check the heater relay solenoid.
2. Check the heater relay solenoid voltage (12VDC) from the electronic.
3. Replace the electronic, if necessary.
Cause:
Excess quantity of detergent or rinse aid dispensed. Excess foam has developed.
Remedy:
Check the dispensed quantities of detergent and rinse aid. Follow the information given in the operating instructions F25 Desired temperature fault At the end of the wash program, the display shows the message Technical fault code F25 - Call Service Dept. The Status LED flashes. The buzzer is activated for 2 minutes. During the heating stage, the desired temperature has not been reached within the given time (minimum 75 minutes). In subsequent wash blocks, after this fault has registered, the heating is not activated and no rinse aid is dispensed.
Cause:
Heater defective.
Remedy:
Replace the heater.
Cause:
Remedy:
Cause:
Remedy:
Mar 15, 2011 | Dishwashers
No keyboard windows sign in
it sounds as if your windows xp pro has not been activated. reload with the proper code or phone microsoft on number stated on activate windows.
hope this helps.
Apr 27, 2010 | Dell Precision 360 Workstation/Personal...
It has a silent mode activated and i dont know how to get it off
In Settings look for Profiles and choose Normal. Or Settings Sounds and increase volume.
Oct 15, 2009 | Samsung SCH-a870 Cellular Phone
SCH-u410 Phone "All Sounds Mode Off Activated"
Press and hold down the # button until it says "exiting silent mode...
Apr 25, 2008 | Verizon Communications Samsung SCH-u410...
One beep activated
Go to Settings > Sound > Volume > Master Volume > It should say "One Beep". Then press the right arrow button and it will change settings. Change it to the Level volume option. You should have your sound back.
Mar 17, 2008 | Lands Phones
Verizon Communications Samsung Gleam Cell Phone - Black Logo
352 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
