The machine is in the on position & won't turn off. The Foot touch on-off red button will no longer press down to turn off. I need a new on-off switch (i think) located above the foot button that releases the handle, above the rollers. (upright machine)
The boss model 4704A
royal vacuum cleaner model 4600 wiring diagram I have a Royal Vacumm Power Tank Model 4600. I...
(More)
royal vacuum cleaner model 4600 wiring diagram I have a Royal Vacumm Power Tank Model 4600. I replaced the switch (6 wire - 3 position) that is on the tank. One side of the switch control just the blower. The other side control the blower and the POWER head - wand with a variable control speed. The middkle position is off. After I installed the swith, the power head - wand is powered in either position. There are three wires comming out of the wand: White, Red and Black. I guess I wired something wrong? Mitch
This is for a Bissell 9500 Proheat 2X cleanshot. I did have some water comming out of the spot...
(More)
This is for a Bissell 9500 Proheat 2X cleanshot. I did have some water comming out of the spot shooter (not after working in it) and not out of the power brush area. I believe (through providing some support) that I am not getting enough suction to make the water flow. There is strong suction through the suction opening. Jim
The powerhead cuts in and out on power as you vacuum with the brushes. Works ok with suction only....
(More)
The powerhead cuts in and out on power as you vacuum with the brushes. Works ok with suction only. Have replaced both wands and still cuts out, Can it be the powerhead connections? Help? TJZ
