Question about Adhesives, Coatings & Sealants
What's a good caulking gun to buy?
    Scholar:
  • 62 Answers
It depends if you are working with soap and water clean up or solvents. Oh yes and if you are neat or sloopy, so here is what I do. Less expensive one for solvents and then toss it if all gummed. It will cost you more in solvent then it's worth. The good or better quality gun is for water soluble caulk. Make sure that any one that you get has NO DRIP feature.
My answers are short and sweet. Common sense mostly. If you are trying to get something for nothing...Don't waste my time! Remember if something sounds to good to be true that it usually is. I've spent many years of my life trying to cheat the system and was pretty good at it. This all changed when I discovered that people were doing the same thing to me. What comes around, goes around. Karma! Now I assist people in making win-win deals...that are legit!
Posted on Nov 20, 2014
    Guru:
  • 269 Answers
For professional work I use the Ryobi 18 volt gun which is a bit more expensive than your basic gun like a Workforce 60:20 gun.
Posted on Jan 10, 2013
How do i caulk my bathtub
get caulk and a caulk gun at the local hardware or Walmart. Load the caulk tube into the tray part of the caulk gun, snip the end of the tube. push on the rear of the tube and slowly lay a bead of caulk around the area of the tub needing caulk.
Apr 13, 2017 | Home
Can this be adjusted / setup for a single cartridge
Buy a single tube caulking gun, you will have more accuracy and less weight, you can buy a good cheap model for about $10 at Home Hardware..
Sep 30, 2014 | Newborn Brothers Newborn 515 20 Oz....
Video on calking tub to floor
I would suggest using 'relief cuts' in the strip so you can make the bend, and then continue -- though using a caulk gun would be better. With standard caulk you can just use your finger and a little water to leave a nice finish. I believe you will find it cheaper as well -- a tube of caulk is around 2 or 3 dollars -- and a caulk gun is a dollar or so.
http://youtu.be/qARPdyLwkb0
Jun 21, 2014 | Home
Cant move caulking gun handle
There should be a thumb release on the shaft at the handle end, press with your thumb and then pull back with the other hand on the shaft. If you have a used tube in the gun, it could be that some of the caulk came out the inside of the tube and hardened so that you cannot pull back the shaft, you will now have to cut the tube off with a utility knife to remove the old dried caulk
Mar 06, 2014 | Draper 43851 Caulking Gun
My caulk tube isnt producing caulk at the tip when its in the gun, theres caulk in there I just cant get it to come out when I squeeze the trigger i've tried multiple times and the bar that pushes the...
It is probably one of two things. Either there is a seal where the tube and spout come together or you may have a spot of caulking that has hardened to the point that it will not come out. Thank you.
Aug 09, 2011 | Home
How do i insert the caulk and how do i use the gun
Cut the end of tube on a angle.There should be a rod with what looks like a plunger at the end.pull the rod back as far as it will go and lock into place.slide tube of caulk into gun with open end of tube towards the plunger.should be a slot at other end where nozzle fits in.take a piece of wire and poke a hole up the nozzle of the tube.release the rod and sqeeze the handle a few times you should see the rod start moving.if not turn the rod until the teeth are facing down.then try again .you should hear a clicking sound and feel pressure and caulk will begin to come out of tube and you will be caulking.Good luck.If you still have problems just come back to fix-ya and we,ll help you through it.
Dec 03, 2010 | Stanley Garden
How do i use the Stanley caulk gun?
All Caulk gun are used the same way no matter which model you have, hear are the instractions
  • Load a tube of caulk into a caulking gun, making sure it's well seated at both ends
  • Use a utility knife to cut the tip of the spout. Cut off as little as possible, taking into consideration the size of the 'bead' of caulk you need. Some people like to cut the spout at an angle, while others cut it straight; it doesn't make a big difference
  • If using caulk that comes in a cardboard tube, look for a second seal at the base of the spout. Insert a nail or awl through the spout to puncture the seal. Many caulking guns come with such a puncturing device. (Plastic tubes usually don't have a second, inner seal.)
  • If you want more precise instruction then go to the link below
    Read more: How to Use a Caulking Gun ' eHow.com http://www.ehow.com/how_8790_caulking-gun.html#ixzz19CNkzmXG
    Here is also a vid that will show you haw to redey the gun for use.
  • Sep 07, 2010 | Grip On Tools Grip Heavy Duty Caulking Gun
    How do you caulk a bathtub?
    First, use a utility knife to remove as much old caulk as possible. Buy caulk(and caulk gun) that is WATER based, DO NOT buy silicone. Cut the tip for about a 1/8 inch hole. Do one wall at a time. Start on a short wall and squirt a bead as best you can. Use your finger to pack it in then wipe it with a wet but well wringed out old t-shirt until your happy with how it looks. Repeat on other walls. John
    Please Rate this solution!
    Mar 15, 2009 | Whirlpool Home
    Iam in the middle of a design project of a caulking gun, rather than jamming what are other problems which are common about caulking guns in general? thanks
    you can leave them down without releasing the pressure and discover when you return that you have a great big mess to clean up...i hope this helps
    Dec 09, 2008 | Grip On Tools Grip Heavy Duty Caulking Gun
    Adhesives, Coatings & Sealants Logo
    1,083 people viewed this question
    Top Adhesives, Coatings & Sealants Experts
    David Payne
    David Payne
    Richard Piatek
    Richard Piatek
    Are you an Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
