Question about Brother HL 5250DN Laser Printer
Add arial font - Brother HL 5250DN Laser Printer
Tip
How to Unlock a 16GB iPod Touch
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
on Dec 16, 2011 | Apple Computers & Internet
Tip
Setup your Belkin
The Pre-Shared Key is your wireless security password, in the form of a word, phrase or series of letters and numbers. The key must be between 8 and 63 characters long and can include spaces and symbols, or 64 Hex (0-F) only. Each client that connects to the network must use the same key (Pre-Shared Key).
The key can be found in 3 different places on your router. The first place is on the wireless security card that came included with your router, it comes taped to the side of your router and fits conveniently in a slot on the underside of your router for storage. The security key is also printer on the top right corner of the product label for your router. This is found on the underside of the router. Finally, you can also login to the routers configuration page to retrieve your wireless key. We have outlined these steps below.
Retrieval Steps
  1. Click on the Belkin Router Manager icon (right-click for Windows) to open the menu, or type 192.168.2.1 into a web browser.
  2. On the Belkin Router Manager menu, scroll up to Router Settings and highlight.
  3. Click to open the Belkin Router Setup page on your Web browser.
  4. You must log in with a password to make changes to your Router's settings. If you have not yet set a custom up a password, leave this field blank and click the "Submit" button.
  5. Click the Wireless > Security link from the page menu on the left-hand side.
  6. On the Wireless > Security page, you can retrieve your password(s) from the fields to the right of the Pre-shared Key (PSK) > entry.
  7. Uncheck the Obscure PSK box to view and retrieve your password(s).
  8. Re-check the Obscure PSK box to obscure your password(s).
on Oct 04, 2011 | Belkin Computers & Internet
Tip
GM OBD1 Codes
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
on Sep 10, 2011 | 1991 GMC Sonoma
Brother HL 5250DN Laser Printer Logo
119 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
