Question about Honda 3000 Watt Portable Generator
Manual honda em 4500 - Honda 3000 Watt Portable Generator
Regulator voltage generator honda EM 1900x
Type honda em 1900x owners manual into your computer search engine, it will bring up sites to get manual.
Apr 25, 2016 | Honda Electrical Supplies
Car keeps dying
no year, stated, impossible to answer nor engine type. of the many.
stalls
try doing the listed 60k tuneup in the service schedule.
open glove box, open operators guide, bingo.
spark parts, filters., fluids, ,can timing belt. see em.
if lost get one.
http://justgivemethedamnmanual.com/honda/honda-cr-v-owners-manuals/
can you save the stall with a fast right foot?
Feb 09, 2014 | Honda CRV Cars & Trucks
Honda life owners manual
life?
ask honda. , yes, ask them. for sure. call em and ask.
not a civic as it say in the above blue box????
The Honda Life is a name that is being used on various kei cars produced by Honda: passenger cars, microvans, and kei trucks. The first series of the nameplate was built between 1971 and 1974, with the name being revived in 1997. The Honda Life has rarely been marketed outside of Japan.
Jan 15, 2014 | 2003 Honda Civic
Where is battery located on honda es 4500
The battery for the ES4500 was not located on the frame of the generator. It had to be added with the battery kit which had a plate and cables that allowed you to connect a 12 volt battery.
Page 8 of the owners manual shows you how to hook up the battery.
http://ubermanuals.com/product/honda-es4500-13340
Oct 01, 2010 | Honda Electrical Supplies
Need service manual for a Honda ES4500 generator
Where do you change the oil on a Honda ES 4500 Generator?
Dec 26, 2009 | Honda Electrical Supplies
What is the Spark Gap for a 2001 Honda Shadow VLX 2 plugs per cylinder?
call honda dealer an he will tell ya over the phone. where ya get the plugs? if parts plce ask em. if wires are bad replace em.
Aug 04, 2009 | 2002 Honda VT 600 CD Shadow
Fuel door won't open on 2003 Honda Accord; can I fix this myself?
open it manually then inspect its lock and release system if either seem malfuntioned try to junkyard the peices and change em out. otherwise it is in your release lever and that im not sure of. ill do research for ya.
Jul 08, 2009 | 2005 Honda Accord
I need to remove the gas tank from a honda generator eu3000is.
I have a ems 4500 honda, the gas tank looks like the upper bar needs to be removed to get the gas tank off, it does. Follow the
top bar down on each of the corners. Where the top bar meets with the bar below the gas tank, you will find a bolt in each of the tubes. Take these screws out, use a hammer to tap the top bar upward lightly at each corner. You should see the tubing sliding up out of the bottom tubes.
Apr 10, 2009 | Electrical Supplies
Generator Armature Removal Honda EMS 4500
Sorry, I don;t have a solution but do you have a good coil from one of those you would like to sell?
Nov 27, 2008 | Kitchen Appliances - Others
Honda 3000 Watt  Portable Generator Logo
52 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
