Question about Zojirushi NP-HBC18 Rice Cooker
Yellow rice
Turns rice yellow and has an odor
How do I get rid of the yellow stain in my microwave I burnt rice this evening & now my microwave has a yellow stain all over it
Maybe Clorox foaming bleach cleaner?
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 05, 2017 | In Microwave Ovens
Over cooked something in microwave and now inside is yellow. How can I return it to white?
Once the plastic is yellowed, there's not much you can do to remove the yellow discoloration. Just continue to use your microwave as usual. If a burnt smell remains, you can heat vinegar in the microwave which will help eliminate the horrible odor--like burnt popcorn!!!! Yuck!
May 23, 2016 | Maytag Microwave Ovens
Phone got wet and phone shows red battary and yellow cation sign
hey the rice trick does sometimes work ya know , google the wet phone to see the rice trick
Jan 22, 2016 | Cell Phones
Sanyo ECJ-D100S Micom 10-Cup Rice Cooker stop working. Just use couple hours ago before it stop working. It is 5, 6 years old, looks like there's no power, only clock. All buttons do not response...
I have the same problem today. I'm lucky to find this thread and fix the problem. The cooker have two broken wires. The good news is that one wire is black and the other is yellow. If both were yellow, I might have to figure out which one connects to which.
Thank you all for the questions and answers,
Liyan
Aug 29, 2011 | Sanyo ECJ-D100S Micom 10-Cup Rice Cooker
The phone was put were there was water then screen went yellow
First of all, do not turn it on. Take out the battery, and completely dry the phone before trying to use again.
Here is the procedure to take out all moisture trapped in the phone: Dry the phone, battery, any accessory, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Apr 26, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
How do you get the microwave clean inside after it turns yellow from a burned itme
1. If the oven cavity is white try using a mild bleach solution to clean. Failing this use Cif as this has an abrasive
2. If the cavity is stainless steel repeat as above but do NOT use wire wool e.g Brillo pad
Feb 17, 2010 | Kitchen Appliances - Others
Purchased Durabrand Rice Cooker model HRC 18G working fine Is there a User manual for this cooker? All that is needed is ratio of water to rice including plain long grain and Basmati rice for 1 - 4...
Instructions quoted from the Durabrand Rice Cooker model HRC 18G manual...... 1 cup of uncooked rice rice will make about 2 cups of cooked rice. Add rice to the inner pot. Maximum four cups uncooked rice for the model. Many varieties of rice can be used including basmati, wild rice, arborio risotto, saffron rice and long grain rice. Whole grains, such as barley can also be prepared with the rice cooker, follow instructions on the package.
For every cup (160ml) of raw rice, add 1-1/2cups of water. For stickier rice add slightly more water, for fluffier rice use slightly less water.
When your rice is cooked, the cooker will automatically switch to the warm function and the yellow warm light will turn on. The cooker will stay in the warm function untill is disconnected from the wall outlet. The cooker will keep the rice warm 158F - 212F
Hope this helps, its quoted right out of the manual I have for my cooker
Jul 27, 2009 | Kitchen Ranges
Status light yellow, won't power on
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
Lcamp518@zoominternet.net
Feb 08, 2009 | Cyberhome CH-DVD 300 DVD Player
Zojirushi NP-HBC18 Rice Cooker Logo
77 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
