Question about Pentax IQZoom 140M 35mm Point and Shoot Camera
Zoom lens not retracting
I own a pentax espio 140 M and the zoom lens does not retract. When I try closing it I get the LE message and it clicks as if trying to close but does not work. Any suggestions?
  • trassh Mar 08, 2008
    Same problem ie. tried to zoom. Once zoom went to maximum extension, a 'HI' message appeared, and cannot switch off or retract. Remove/replaciing battery doesnt help.
    Genius:
  • 2,985 Answers
May be a bit of grit gas got in. Do not try to manually manipulate it- this will wreck the motor drive. A Vacuum clean suck way have some affect. Certainly contact Pentax Tech Support Team .
Posted on Jul 02, 2007
Need to find manual for Pentax Espio 120 Mi
The Espio 120mi was called the IQ-Zoom 120mi in some parts of the world. You may download a copy of the IQ-Zoom 120mi manual here.
Apr 04, 2012 | Pentax Photography
Digital zoom error on an A600, lenz will not retract either
Have you tried spraying a can of compressed air into the lens assembly? All it takes is small piece of debris like a grain of sand to jam up the assembly.
Hope this helps
Jul 07, 2008 | Fuji FinePix A600 Digital Camera
Automatic lens cover only shuts
Greetings,
Use the power adapter that came with the unit.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 23, 2008 | Cameras
How much is a Pentax esp10-140 worth?
I found the ESPIO-140M selling for as little as $30, and I found an ESPIO-140V in excellent used condition selling for $150. I also noted a 140V that failed to sell for $55 on eBay. I hope this information helps.
Here's a link to the high priced V model:
http://www.porterelectronics.com/servlet/the-342/Pentax-Espio-140V-35mm/Detail
Jan 26, 2011 | Pentax Cameras
U7 error code when Pentax Espio 200 camera switched on. What does it mean? Can I rewind and remove film to develop?
Its actually a technician code which means that your Zoom system has malfunctioned. If you want to remove the film then you can simply click the reset button and then remove the film. If you want to get it repaired then it would be better if you throw it and look for a new SLR Camera
Oct 22, 2010 | Pentax Espio 200 35mm Film Camera
My pentax option A10 turned black on the screen and won't open
Since the screen went black BEFORE the lens retracted, it makes me think this is a main board problem. The only other possibility is that it is the lens assembly, but since it went black BEFORE the lens retracted, I don't think that is it. I can replace the main board for $40, or you can send it to pentax in Arizona, and they will do it for about $90.
The main board is NOT something that I would suggest anyone try to replace as a DIY project. There are too many small screws, and delicate connections to deal with.
You can contact me at: mrfixitmark at comast dot net
If you just want to sell the camera as-is, I also buy all pentax a10, a20, a30, a40 cameras, in any condition.
Mar 28, 2010 | Pentax Optio A10 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Lens won't retract
You could try to gently pull the lens straight. If it's leaning to the right then pull the lens to the left. Don't use brute force but it's possible to realign the lens this way. If it works you'll hear a click and the lens will look straight. Switch on and see if it retracts. I'd only use this as a last resort because you can cause additional damage if it's overdone. It has sood success rate also
Sep 06, 2009 | Pentax Optio M20 7MP Digital Camera with...
Shutter permanently open and zoomed. will not close in even without battery. tried new batteries, no change
It needs factory repair - find another used camera or buy a new digital. That camera is not worth spending the money on to repair.
Aug 10, 2009 | Pentax Espio 115V 35mm Film Camera
Pentax IQZoom 140M 35mm Point and Shoot Camera Logo
153 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
