Question about Dishwashers
Reset kitchenaid kuds30ix - Dishwashers
KitchenAid Blender
The motor will probably be open circuit, take it back under guarantee and let them sort it out. If you mess around you will void your guarantee.
Aug 05, 2014 | KitchenAid Blenders
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
Upper rack falls out each time we pull it to fill or empty. The wheels on the rack seem to be detaching
Can you find a new basket or just the wheels. I would try Google or ebay or this site sell spares I think
Sep 20, 2013 | KitchenAid KUDS30IX Dishwasher
Reset button not working on kitchenaid garbage
Look for small pieces in the disposal... likely pits, glass, etc once these are removed press the reset. also check the breaker. Double breakers can be tripped but you can't tell to look at it. Just shut it off and turn it back on.
Aug 22, 2013 | Hardware & Accessories
Where is the reset button on kitchenaide
What is your model number? There is no reset button.
Aug 13, 2012 | KitchenAid Dryers
How do I read the fault codes for my kuds30ix dishwasher
Take off the bottom kickplate, where the water and electrical hook up. Somewhere on the back of that kickplate or under the machine by usually by the inlet valve there should be a sheet with trouble codes and troubleshooting procedures on it.
Jan 30, 2011 | Dishwashers
Kitchenaid kebs177 continues to beep, no display, clock works onl
Hi. try to reset this unit by killing the power or unplugging the cord for 5 minutes. this will reset the control. if the control continues to beep after you reset, this will confirm control failure. you will need to replace the control board in this case.
May 22, 2009 | KitchenAid KEBS177 Electric Single Oven
Kitchenaid Microwave went blank
Is there a reset button or something I am not aware of?
May 20, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
