Question about Rti Technologies T2+ Remote Control
Channels will not advance
Volume works
Interment or no volume on certain channels.
make sure set not set to sap mode as this can blank audio on certain channels
Sep 03, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
Channels for my z-5300 logitech not working
If you are having problems with you sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 21, 2011 | Logitech Z-5300 Computer Speakers
Will not change channels, but volume works.
try numeric keypad, if unsuccessful then try reloading TV code in remote
Mar 19, 2010 | Philips Magnavox Learning Universal Remote
I have CC on my TV and want to reset it as the remote has stopped working using Universial one
You will need to get a replacement for the original remote. Universal remotes can take care of the most basic functions such as on/off, volume, channels etc. but generally do not allow control of more advanced menu functions such as CC. Try partstore.com where you can search by brand & model.
Nov 18, 2009 | Philips Televison & Video
Left channels not working
Check out the left channel amp stages - your issue is there.
Apr 30, 2017 | Yamaha RX-V395 Receiver
Microphone fuzzyness
there may be some problems with your volume leveling. i have insalled programs that have come packed with FREE, that's right, FREE trojan horses, spy ware and other malware that love to mess with my volume levels. open volume control by double clicking on the volume control icon on the taskbar or going through control panel. mute any channels you don't use such as phone line. test. if that doesn't work, there may be an advanced button on the microphone volume control. click it. in the screen that appears, you might try checkig/unchecking the mic boost. -answer for windows xp. i dont have much experience with vista
that, or you may have a bad connection
Nov 24, 2008 | Dell Vostro 1500 Notebook
No Windows Media Player Audio from Surround channels
On WMP - go to Tools > Options > Devices > Select Speakers > click Properties > Audio Device to Use - ensure you select your audio Card (Not direct sound - just a precaution) > Advanced > Volume Tab > Speaker settings click on Advanced > Select the type of Speakers you have. - Hope this helps, let me know!
Oct 28, 2008 | Creative Labs Audigy 4 Sound Card
Olevia/Syntax 20" Television
Make sure that the channels that you are not getting audio on are not HD or high definition channels. Also make sure that they are not digital channels. There is absolutely nothing wrong with your TV, so rest assured it is correctable iether in the menu or you may want to perform another auto search for your tuner.
May 31, 2007 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
Rti Technologies T2+ Remote Control Logo
13 people viewed this question
Top Rti Technologies Televison & Video Experts
Tom Chichester
 Grubhead
Grubhead
Are you a Rti Technologies Televison and Video Expert? Answer questions, earn points and help others
