Question about Smartpaw Play Sights & Sounds Birdie Chase Cat Toy, 1ct
How do you replace the battery in the play sights & sounds birdie chase
When playing 9-hole golf and I have birdies there are still points deducted from my total. Why?
fixya didnt play with you /doesnt know your handicap or what your original score is so your on the wrong site -notify score keeper or golf manager as to why points deducted
Jun 06, 2017 | Cars & Trucks
Trouble turning Amp on with remote CR-100. It takes 6 time's pushing the button to turn amp on.
This sounds like a low battery issue. Replace the batteries in the remote and try again. Be sure you have 'line of sight' with the receiver.
Tip: You can check if your remote works by pointing it at the lens of a smartphone or digital camera. The remote works if you see a purple coloured light.
Jan 24, 2016 | Audio Players & Recorders
I got a notification sayin that madison rodrigues sent me a gift on dragon city I click the notification. On dragon city the gift was from birdie mae not Madison rodrigues.
If Birdie May is a friend or acquaintance of yours, does that person have a working computer? If not, perhaps someone else sent you this message for that person. Be blessed.
Jun 15, 2015 | Computers & Internet
What size batt for freestyle diablo mid?
Hmmm, seems trivial but: did you already open the case & check the exisiting battery? Voltage & size are crucial to finding a replacement.
This conversion chart might help (open the sight for more details & tips):
WATCH BATTERY CELL CONVERSION CHART
May 18, 2015 | Miscellaneous
I have a Uniden bc95xlt scanner! it is less than 1 yr. old. it will lock on to a channel and not unlock to continue scanning. I can't find my paperwork to prove age of scanner! Pls. Help!
Hi Jan,
It sounds to me as if your scanner is locking on to a 'BIRDIE', which is an internally generated frequency in the scanner, all scanners have this by default, your user manual usually has a page, near the back of the manual, with known 'birdies', and there a lots.
When your scanner locks onto a 'BIRDIE', which is a frequency with no voice audio, the best thing to do is press Lockout button, during the scan, your scanner will, if there is no other problem with it, continue to scan, until it finds another 'BIRDIE', then you do the same thing as I've described, until you've locked out all the 'BIRDIES'.
I hope this info was useful.
Cheers,
Peter.
Jan 23, 2013 | Uniden Bc95xlt 200 Channel Scanner
When I recieved my BC Rich Virgo celtic bass there was no problem. I played with it for almost an hour. Later I wanted to play another time so plugged it in. No sound came from my bass. I tried to replace...
Intermittent problems can lead one on a merry chase. The first suspect would be the guitar cable.
Players learn to check the connection to the amp is good by touching the tip of the cable and observe you get hum.
It is UNLIKELY to get two bad guitars so we need to check everything else. Cable is next suspect.
Check the cable IS for intruments and NOT speakers. Check that the tips do not spin. Some cables become worn and the sleeves no longer actuate the switch that turns the battery in the guitar on or the tip fails to make contact. Do not use cables that are intended to connect stereo systems. Use ONLY instrument rated cables.
Feb 24, 2011 | B.C. Rich Virgo Vintage Celtic 4-String...
What is the procedure for sighting a zeiss z-plex reticle scope?
mount it, get a 100 yard target, and you have to chase the bullet right is left up is down
Sep 07, 2009 | Zeiss Conquest w/Z-Plex Reticle/Side Focus...
Cannot get the gun sights to move in wii play
Ensure that your not too close and not too far from your TV, and make sure that your sensor bar is properly set atop (or below) the screen.
Aiming takes a minimal amount of movement once you get your cursor on the screen. Big motions are not necessary to move your sights around the screen - just little movements with the wrist. Once you find that sweet spot, you should get good experience with the Wiimote.
Finally, make sure the batteries in your sensor bar (if you are NOT using the one that came with your Wii) and the batteries in your remote are fully charged. To know if the batteries in your Wiimote are charged, the first time you press a button on the Wiimote after turning on your Wii, you'll notice that 1 to 4 of the blue LEDs will be blinking. If all four are blinking, the batteries are good. If only one blinks, time to replace them.
**NOTE: If you don't like my advise, that's fine. But please don't rate me a '1' just because my answer doesn't help. That's what 2 diamonds are for. Thanks!
Feb 04, 2009 | Nintendo Wii Play for Wii
I have no power to the the radio
You will have to chase your power wire back to the fuse panel and/or the battery itself. The burning smell was more then likely the main power cord burning up. Replace it and it should all work well.
Dec 16, 2008 | 1992 Honda Accord
Smartpaw Play Sights & Sounds Birdie Chase Cat Toy, 1ct Logo
106 people viewed this question
Top Smartpaw Cats Experts
Tom Chichester
Ruth summersides
isojim
Level 1 Expert
Are you a Smartpaw Cat Expert? Answer questions, earn points and help others
