Question about Play Inc Bob the Builder Friction-Powered Roley Vehicle
Batteries are dying in bob the builder roley toy
Is there a way to open the toy to replace the batteries cos when my son presses the button the toy just makes a contunious da da da da da da da sound. doing my head in is an understatement!!
How long will it take to charge?
It depends on what your charger is putting out, if you have a charger that puts out 1amp and a 6volt 4.5 amphour battery then it will take appox 4.5 hours, check the output on the sticker of the charger and make sure that it lists 6-7.2 volts, then if you can check the charger with a multimeter and make sure that its showing 6-7.2 volts
Jan 17, 2013 | Learning Curve Toys Bob the Builder...
Lost the charger, need a replacement
You should be able to find one here scroll down some and there is a 6v charger http://www.impactbattery.com/catalogsearch/result/?q=bob+the+builder+scrambler+charger
Jul 05, 2012 | Learning Curve Toys Bob the Builder...
How do i reset my computer so my son has more free sessions on his games
well... you could try and delete your cookies via ccleaner and see if that helps, you can download ccleaner from piriform.com. if that doesn't work, then i don't know, you may just want to google "free bob the builder Games" that might get you one you can download that your son can play over and over
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 02, 2012 | Dell Computers & Internet
I have a Bob the Builder ornament holding a Xmas tree. Half the tree is gone leaving an exposed metal rod. How do I replace the lost tree material?
Hi, Hobby Lobby and other "craft stores" have mini trees. Also, small trees are used in model rail roads which can be found on E-bay. Buy the tree and twist it on to the old wire.
Jan 08, 2012 | Toys
After using the computer twice,it stopped working.we changed batteries to no avail. it was bought dec2009.smyths was contacted where it was bought,but couldnt be replaced as it had gone out of stock....
Usually the manufactures warranty covers material defects for a limited time, and ranges from 90 days to 3 years. I have never seen a warranty for a computer more than 2 years personally, and you bought the computer 8 years ago. Unfortunately I think you will need to pay for the repairs yourself.
Dec 01, 2017 | Bob The Builder Toys
I have the Peg-perego Battery Operated Thomas the tank engine Ride-on. We bought it in 2006, used it a couple times...put it away bc my son was afraid of it. now my other son wants to ride it. When we...
I would check the battery voltage with a multimeter if possible. Battery should read at least 6 volts. Most likely the battery is too old to take a charge if it’s been sitting unused since 2006. I’d replace the battery first and then go from there.
Oct 07, 2017 | Learning Curve Toys Thomas the Tank Engine...
good day,
hope this link below answer your query.
toys
Mar 27, 2009 | Learning Curve Toys Bob the Builder...
WE NEED TO PURCHASE A REPLACEMENT CHARGER
You should be able to find a replacement charger at www.batteriesplus.com
Mar 23, 2009 | Learning Curve Toys Bob the Builder...
Dino Buddy not responding to r/c
I Replaced the batteries in the dinosaur, because mine did that after only a few hours. when the batteries start to die, only the demo switch works...
I hope this helps!
Nov 29, 2008 | Lillian Vernon Remote Control Dinosaur...
Play Inc Bob the Builder Friction-Powered Roley Vehicle Logo
47 people viewed this question
Top Play Inc Toys Experts
degroot2940
Tom Chichester
Bill Boyd
Are you a Play Inc Toy Expert? Answer questions, earn points and help others
