Question about Adhesives, Coatings & Sealants
What is caulk? - Adhesives, Coatings & Sealants
    Guru:
  • 269 Answers
It's a waterproof sealant used in household repairs and building.
Posted on Jan 10, 2013
How do i caulk my bathtub
get caulk and a caulk gun at the local hardware or Walmart. Load the caulk tube into the tray part of the caulk gun, snip the end of the tube. push on the rear of the tube and slowly lay a bead of caulk around the area of the tub needing caulk.
Apr 13, 2017 | Home
My tub is plastered into the wall with caulking. Recently, I have noticed that the caulking is dissapating and loosening up the tub. Fortunately, I have not see a change in my water flow. I want to
Unfortunately this is usually caused by a leak and the drywall is wet , and or the tub is sinking due to water damage to floor. If the drywall is solid then use a utility knife to remove old caulk, then after area is clean apply silicone caulk around the tub. apply neatly but with plenty enough to fill the void. I then spray a dish soap an water mixture on the calk then remove excess by pressing thumb down and sliding it long caulking. This presses it into the gap and also removes excess, which leaves you a neatly caulked tub.
Jan 23, 2015 | Pfister Tub and Shower Repair Kit SK0275
How to take old tub caulk off a vinyl floor
Check your local DIY center there are tools for doing this safely with no damage.
Jul 28, 2014 | Color Rite Color Caulk New Age Oak
Cant move caulking gun handle
There should be a thumb release on the shaft at the handle end, press with your thumb and then pull back with the other hand on the shaft. If you have a used tube in the gun, it could be that some of the caulk came out the inside of the tube and hardened so that you cannot pull back the shaft, you will now have to cut the tube off with a utility knife to remove the old dried caulk
Mar 06, 2014 | Draper 43851 Caulking Gun
Applied DAP latex with silicone caulk around exterior window sill in dry condition. No rain for 7 days. Rained last night and tiny string of bubbles surfaced on full length of caulk application. Paint:...
Try using the dap window caulk. The window was probably washed just prior to you applying caulk and was not totally dry. The dap I mentioned should work in this situation. I used to use the cheapest caulk I could find...mistake! There are different caulks that do different things, add moisture and... I'm sure you get the pix.
My answers are short and sweet. Common sense mostly. If you are trying to get something for nothing...Don't waste my time! Remember if something sounds to good to be true that it usually is. I've spent many years of my life trying to cheat the system and was pretty good at it. This all changed when I discovered that people were doing the same thing to me. What comes around, goes around. Karma! Now I assist people in making win-win deals...that are legit!
Oct 08, 2013 | Dap 18725 16OZ White Latex Caulk
What is Silicone Caulking for?
Silicone Caulking is a kind of caulking material that can be used for basic sealing against water and air penetration.
Jul 16, 2013 | Adhesives, Coatings & Sealants
Knob and Tube Wiring...Which caulk is safe to use around it?
you can use silicone caulk for kitchens and bathrooms. this is the kind for caulking around bathtub enclosure and it comes in clar or white. can be bought at walmart , lowes or any good hardware or building supply company
Sep 14, 2012 | Cars & Trucks
How do i use the Stanley caulk gun?
All Caulk gun are used the same way no matter which model you have, hear are the instractions
  • Load a tube of caulk into a caulking gun, making sure it's well seated at both ends
  • Use a utility knife to cut the tip of the spout. Cut off as little as possible, taking into consideration the size of the 'bead' of caulk you need. Some people like to cut the spout at an angle, while others cut it straight; it doesn't make a big difference
  • If using caulk that comes in a cardboard tube, look for a second seal at the base of the spout. Insert a nail or awl through the spout to puncture the seal. Many caulking guns come with such a puncturing device. (Plastic tubes usually don't have a second, inner seal.)
  • If you want more precise instruction then go to the link below
    Read more: How to Use a Caulking Gun ' eHow.com http://www.ehow.com/how_8790_caulking-gun.html#ixzz19CNkzmXG
    Here is also a vid that will show you haw to redey the gun for use.
  • Sep 07, 2010 | Grip On Tools Grip Heavy Duty Caulking Gun
    Adhesives, Coatings & Sealants Logo
    787 people viewed this question
    Top Adhesives, Coatings & Sealants Experts
    David Payne
    David Payne
    Richard Piatek
    Richard Piatek
     perry tradesman    ...
    perry tradesman ...
    Level 1 Expert
    Are you an Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
