Question about Uniden DXAI4288-2 Cordless Phone
Can't dial out
We bought a new dual cordless, and we can receive calls, but the phones will not dial out, all you get is a dialtone when you try to dial a number. any help with this?
  • Anonymous Mar 23, 2014
    I have checked the phone on a jack used with a working corded phone and the troublesome phone, which has nicely working buttons and a good clear dialtone, will not register the numbers entered. Dialtone remains constant. Is there a setting? model 29385GE2-A
    Novelist:
  • 201 Answers
Can you hear the tones when you dial? Is there a (tone / pulse dial) switch or programming option?
Posted on Jul 07, 2007
6ya staff
SOURCE:
Why no dial tone. Only static?
Check the phone line were it comes into the house there is usually a point where the phone connection from the the TELCO outside wires connects to the inside wiring.
Remove the inside wiring and test the wiring that is on the TELCO side. If you get dialtone the trouble is in the inside wire. If you don't get dialtone call TELCO
Aug 26, 2014 | Lands Phones
I have a dual handset and on both it says searching...when i try to dial out i get no dialtone
try to take out the battery and then insert it again hope it will help you worked for some similar devices of mine
Jun 21, 2011 | Uniden D1680 Cordless Phone
My phone says check Tel Line
Sounds like your telephone line might be dead. If you have a gray or tan telephone box on the outside of your house you can plug your phone in there to test the line. If you get dialtone then thrers a problem in your house wiring, if you don't get dial tone then the line is dead and you need to conact your telco provider.
Apr 14, 2010 | Uniden DECT 6.0 Cordless Telephone...
My Uniden wireless phone doesn't have a dial tone,
I would be willing to bet that it's the line cord that is plugged into your phone's base unit. Try a different cord, and/or try it on a different jack.
If it's neither of these, see if any phone you have gets dialtone. If no phone gets DT, contact your service provider. If other phones work, and the new cord didn't fix your Uniden, then chances are that the jack has been ripped from the circuitry. If that's the case,
contact us at IdacomUSA and we'll be glad to set you up properly.
Jun 17, 2009 | Uniden EXS9950 900MHz Cordless Phone
Dialtone, but no dialing
Uniden offered a replacement, stating that the base phone was probable beyond repair.
Jun 04, 2009 | Uniden DECT 6.0 Cordless Telephone...
Just bought phone no dial tone i move the setting to pulse
First thing to try is another phone in the wall jack if it doesn't work either you need to call your phone company. If the other phone works, make sure that the telephone is getting power from the AC electrical outlet. Try swapping the telephone cord with another cord. and lastly, unplug the battery from teh handset and plug it back in untill you feel it click into place. Sometimes the new battery connections are pretty tight and may not really be connected even though it looks like it is plugged all the way in.
Mar 23, 2009 | Uniden 5.8GHz Dual Cordless Phone
No dialtone
If you use Dsl as a internet provider make sure you have the filters on each phone. If you use cablevision and have a wireless connection make sure you chage the phone to a 5.2ghz because you might have the wireless router with the same ghz causing a coflict. This will also create loss. of internet connections then you use the phone
Jan 19, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
Dialtone
http://www.retrevo.com/samples/GE-manuals.html
follow the link above and also try to get an earlier or newer moddel manual ;) take care
Oct 22, 2008 | Uniden Cordless Phone
Cannot call out or answer a call
The only thing I can think of is you may be in the wrong dial mode. If you do not have touch tone service you will hear the tones but it will not connect. Try setting it to pulse and see if you can call out. Check you volume or see if the mute has been set. Have you tried a different phone? you might want to borrow a phone from a neighbor to see if it is a service problem or just your phone.
Feb 01, 2008 | Panasonic KX-TG6021 Cordless Phone
GE 28111 Twin Cordless Phone "Line In Use"
I had the same problem. I went to each handset and pushed the talk button. After I got a dial tone, I pushed it again to stop the dial tone. The message went away.
Aug 14, 2007 | GE 28111 Cordless Phone
Open Questions:
See all Uniden DXAI4288-2 Cordless Phone Questions
Uniden DXAI4288-2 Cordless Phone Logo
197 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
