Question about Delphi Car Audio & Video
Need xm kit for xta 2400 - Delphi Car Audio & Video
I have a 2011 Honda Pilot. When I push the XM button it won't even change over to the XM radio. It is like there is no XM capability in my car. What can I do?
Often times you'll need an aftermarket integration kit to get an XM ready car radio to work. This is a two part system including the tuner to tie the subscription to and a translator to code it so the radio face will understand and display the information accurately. You can find such a kit for your car here: http://www.tss-radio.com/isimple-factory-ipod-xm-integration-for-honda-acura-vehicles-hd1.html
Nov 10, 2013 | Cars & Trucks
Why can't i get oprah on my sirius radio natalieromyn@shaw.ca
On Sirius radios, some programs require a subscription to the "Best of XM" and on some XM radios, you need a subscription to the "Best of Sirius" to get their programs. Call XM/Sirius and ask them, but I think that you have to pay extra for the "B.O.XM".
Jan 18, 2011 | Sirius Sportster 5 Satellite Radio...
I have a XM Model 136-4335. I need an operators manual. I need to program preset stations and don't know how. Thanks, Mike
The XM model number provided is branded DELPHI but is actually made by AUDIOVOX... a manufacturer that is commonly rebranded XM, TERK, RCA, etc. So the Audiovox manual is what you need. Now since Audiovox usually doesnt support directly its hard to get manual from them directly. The link to your manual (the third down on this page and the picture looks a bit diffferent but is the silver receiver not black box ones) Good luck
http://www.retrevo.com/support/Audiovox-XM-Satellite-Receivers-manual/id/395ag115/t/2/
Jun 02, 2010 | Delphi XpressRC XM Satellite Radio...
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
XM Direct 2 firmware download
well that could be like the problem i am having. you need to do it on windows xp it will only work with windows xp
May 09, 2009 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
The remote does not turn on the Delphi XM Xpress on car unit
This problem is caused due to the fact that xm has designed there radios to completely shut off all power with the unit therefore the unit once off will not be able to recieve information from the remote. This manufacturing defect was confirmed by the xm representative, they also explained that the company is currently planning to fix this issue on the new 2009 model xpress rc
Mar 30, 2009 | Delphi XpressRC XM Satellite Radio...
My delphi xm is frozen
Hold the up volume button and the mode button at the same time. I have to do it almost every day. This is only a problem when using the car kit. No problem at all when using with portable kit or home kit.
Dec 18, 2008 | Delphi SKYFi3 XM Radio Receiver
Xm radio installation in house
hi there..this will be like a walk in a park...first, in your home kit you should be having the ff: antenna, rca cable(audio cables), power adapter & docking station. We just have to 'placed the radio into the docking station' then we just have to plug in the ff cables into the xm receiver..we can start plugging in the rca cable(one ended connector) into the ' audio out ' of your xm radio...the other ends of the rca cables should be plug in into the 'audio in'(at the back/infront of your sound system)...plug in the antenna in the 'antenna out' of your xm( the antenna should be placed into a south facing window and not being block by tall trees and buildings outside)....plug in the power source and turn on the radio....if you got it right you should now be getting the prev.channels/emergency allerts...u can call xm to send a refresh for you to get the complete channels..or you can do it online by logging into www.refresh.xmradio.com(if the radio was already activated) if not, you have to call xm radio to activate it..enjoy listening to xm..Godbless..
Sep 05, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Car Audio & Video Logo
37 people viewed this question
Top Delphi Car Audio & Video Experts
Lawrence Oravetz
Sam Bedggood
Andrew Taylor
Andrew Taylor
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
