Question about Brookstone Handle-Mount Grill Light
How do I put batteries in the brooks tone BBQ grill light
I had same problem. Note you cannot see down the Battery tube as there is a top attached to the battery cover that turns. I worked a very thin screwdriver head between that top and the light unit, and the cover then wiggled free rather easily.
Posted on Dec 25, 2013
Where is the battery located on this grill?
No battery. The igniters are piezo style that doesn't use batteries. If it has failed, you can get a replacement at any store that sells BBQ grilles or home improvement stores.
May 04, 2017 | Grilling
How do you change the batteries of the bbq grill light
The battery compartment is the opposite end of the light from the on/off buttons. Turn it counter clock wise about 1/2 turn and the batteries should push the end cap out. Remove it all the way. If the unit is new and doesn't have batteries you might have to pull the end cap to get it free of the compartment. Once the cap is free tip the batteries out, replace with new batteries, replace the cap and tighten by turning it clock wise.
Nov 05, 2013 | Brookstone Handle-Mount Grill Light
I just bought the small Char-Broil American Gormet Smoker BBQ and Grill. The lid doesn't close tightly. One side of the gill is about 1/4" to 1/2" open while the opposite end closes...
Glenda, you can try adjusting the hinges, to help square it up. But, if the lid was damaged or sprung during shipping, there's not much you can do, except contact Charbroil Customer Service 1-866-239-6777 for a replacement. Adding a sealant is not an option.
Jul 07, 2011 | Char-Broil American Gourmet Grill
How to char-broil burgers
You want to know how to char broil hamburgers right? Here is what you do! Start your BBQ 5 to 10 minutes before you put your burgers on (for gas BBQ) and let the metal racks heat up. Keep the top closed to let the heat go through the unit.
If your using a charcoal bbq wait until your coils are white hot and the racks are as hot as you can get them.
Don't buy the hamburger meat that has the smaller amount of fat in it. Get the stuff that has 15 to 20% fat in it. The juice in the fat will help cook the meat and taste better in a burger.
Put your rack on the lowest place as close to your fire/coals as possible.
When the bbq is hot Take your patties and plut them on the rack. If its hot enough you should hear a sizzle sound. DO NOT TURN THE MEAT. Let it sit on the grill and every few minutes take your spatula and press the meat flat on the grill to release more juices and get more attention from the flame or coals. This is what makes the black grill lines on the meat.
You only flip a grilled burger one time after putting it on the bbq. It should cook at least ten minutes or more on one side. If you turn the meat and there are no marks on it then you didn't wait long enough.
Sep 29, 2010 | Computers & Internet
Our igniter doesn't work.
clean the elctordes on the burners make sure the battery conections are clean corrosion free
Jun 21, 2010 | Weber Genesis E-310 Gas Grill
My turbo built in bbq has 4 burners. what do the
the burners need cleaning remove burners put them clr or clean out burner holes with a paper clip screws are air gas mixture best left as they are
Jun 21, 2010 | Barbeques Galore Turbo STS 4-Burner...
Bought a used BBQ Galore Turbo BBQ CG4tdbrn
Hello, I wasn't able to find a manual, but I did get the manufacturer's toll free customer service # 1-800-752-3085. See what they can do for you.
May 21, 2010 | Barbeques Galore Turbo STS 4-Burner with...
Ignitor on gas BBQ no longer works. Replaced battery and cleaned out chamber (light rust). I've tried to remove the ingnition housing, but the entire front panel of the BBQ needs to be removed. Suggestions...
Check to see if the probe where it sparks to the burner inside the grill is clean and not shorted by grease or other gunk and the burner itself in this area is not too heavily rusted or corroded. If not, short of disassembling the whole grill and replacing the spark module, spend $2-3 and buy one of those pistol type grill lighters. The ignition systems on BBQ grills rarely seem to last long.
Feb 24, 2010 | Grilling
Brookstone Handle-Mount Grill Light Logo
2,403 people viewed this question
Top Brookstone Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Brookstone Grilling Expert? Answer questions, earn points and help others
