Question about Canon imageRUNNER C3170U Color Copier
I receive an error E000013-0000
Once I turn on the copier, it loads then an error message shows up that says: "Shut down the machine and turn the power off and turn it back on. If you receive this message again contact your rep. Error Number: E000013-0000. Let me know if anybody can help, I would appreciate it. Thanks.
  • Anonymous Jun 16, 2008
    where is the toner waste? lol!
  • 186 Answers
Check your toner waste bottle it may be full. Also the tube that transports the wast toner may be clogged. In which case its time to call a tech. John
Posted on Jul 03, 2007
U r worrang it toner wast
Posted on Aug 11, 2012
You were correct ... it was the toner waste.... it was full
Posted on Jul 19, 2007
GARDEAS YARDIM EDIN YA
Posted on Oct 17, 2008
2 Suggested Answers
sir fixalot
  • 146 Answers
SOURCE: I receiver error number E000067-0110
The error indicates a high voltage problem with the primary or transfer units. The most likely cause is the main drum being worn out.
This can be checked by going into service mode. You can do this by pressing the star button once, then press 2 and 8 at the same time, then the star button again. Now a word of warning. Do not change anything as it is very easy to turn your copier into a cabage!!! Press the tab marked COPIER, then the one called DISPLAY, next the one called MISC. You will see an item called DRUM LIFE, if it is 80 or more the drum will need replacing. Hope this helps.
Posted on Jan 02, 2008
In netflix/Movies refuse to load.error message
sounds like your internet is down . Id call your isp
May 19, 2014 | Apple Televison & Video
I have a ip43oo and I get service error B200 What is it?
Your Pixma ip 4300 error B200 definition: Over-heated print head. It sounds like an: "ut-oh', but not a big deal. The reason the print head overheats? Ink needs to be replaced... Replace the ink cartridge that is low (you should have received that message at least once).
I would shut it down to prevent damage, until you can get the ink cartridge replaced.
Mar 17, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
Canon ir2116j the problem is after pressing the print butten the lamp carrage not moving right side and display light shut down then again reset what is this problem
wich is the error code that machine shows? i.e. E00002-000
You said that machine says turn off and on, these happens when the error code is present.
And by the way do you mean IR2016J, 2116 do not exsist!
Aug 24, 2010 | Canon iR 2016i Black and White Copier
Installed new staple cartridge; display showed message 'shut off/shut on'. I did that and now the copier won't power on.
Take the staple cart. out and power off and on. Mite have been a fluke but had and additional problem once you turn on the machine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 17, 2010 | Konica Minolta Office Equipment & Supplies
I have an error message that reads ob. I have an
OB MEANS OFF BALANCE if the motor controller detects an unrecoverable off-blance condition, the machine controller will shut down and display ob. the lid switch must be opened at least once before restarting the cycle if this condition occurs. opening the lid will allow you to view and redistribute the load. press stop/cancel to clear the display. hope this helps.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
May 13, 2009 | Konica Minolta bizhub C250 All-In-One...
Dec 31, 2007 | Canon imageRUNNER C3170U Color Copier
Printer Error Message after changing the cartridges
I'm not even pulling up any info on that error msg.
Where are you reading the error msg from, within Windows? Or from the printer itself?
Oct 23, 2007 | HP PSC 2355 All-In-One InkJet Printer
Canon imageRUNNER C3170U Color Copier Logo
4,797 people viewed this question
Clive
Clive
old marine
old marine
